Gold Member Username: DelsolePost Number: 1493 Registered: Feb-05 | OK i'm a little new to the who box building thing. I made a box for a jlw6 a while back but i just followed the directions off the jl sit. First off i need to know if i can fit the 15 hdc3's or if i will have to go with the 12's. My measurement show that i have about 9 cubic feet to work with. I tried making a couple sample boxes on reaudio.com but it seems i might not have enough volume once the port and driver are added in. I can squeeze a little more out if i have to. I would like to keep my trim in though. Another dilemma I'm running into is i cant make up my mind which way i want the subs to be facing along with the port. let me know what you guys think and if you have any articles or so forth for beginner spl box builder's i would love to read them. |
Gold Member Username: DelsolePost Number: 1494 Registered: Feb-05 | |
Gold Member Username: DelsolePost Number: 1495 Registered: Feb-05 | |
Gold Member Username: DelsolePost Number: 1496 Registered: Feb-05 | My length is about 40 inches the depth is about 30 and my height is 16 inches. |
Gold Member Username: DelsolePost Number: 1497 Registered: Feb-05 | I would have kept everything in the other post but it seemed to be getting a bit cluttered. |
Gold Member Username: Dustin3Box Designer & Builder...Dustin Post Number: 5577 Registered: Oct-05 | It could be done, I would have to sketch it out and see if they would fit but it's definitely possibly especially if you used aero's. |
Gold Member Username: DelsolePost Number: 1498 Registered: Feb-05 | Where can i buy or what is recommended to use as areo's? |
Gold Member Username: DelsolePost Number: 1499 Registered: Feb-05 | I really like the way this box looks. I don't have the height to make that but i think i can make up for it in the length. Does anyone know what this box is tuned to? And perhaps How many cubic feet is is? |
Gold Member Username: Dustin3Box Designer & Builder...Dustin Post Number: 5579 Registered: Oct-05 | http://www.parts-express.com/pe/showdetl.cfm?Partnumber=268-352 That's an aero. |
Gold Member Username: Kyle_lowePost Number: 1067 Registered: Apr-06 | here is the link to the 6" flare ports you can just navigate back to the port tubes page to find the smaller sizes http://www.parts-express.com/pe/showdetl.cfm?Partnumber=268-354&vReviewShow=1&vReviewRand=2775929 and here is the link to the calculator for those ports http://www.psp-inc.com/tools.html |
Gold Member Username: DelsolePost Number: 1501 Registered: Feb-05 | Do these ports sound as good as slot ports? |
Gold Member Username: Dustin3Box Designer & Builder...Dustin Post Number: 5580 Registered: Oct-05 | Yes, and they displace less volume. |
