Renault Laguna radio code
Username: Gab9836
Hi, I disconected my batery and now my radio asks for a code, I wrote down all the numbers, because I`m not sure which numbers do You need, here they are:
model no. : 22DC279/62
prod no. ; FD0100080024946
RN279F0024946
7700433948TC284
please, please help, I go mad driving to work with no radio.
many thanks
Username: Regrooster
Post Number: 4047
Try code 1 7 2 4
Username: Gab9836
1724 doesn`t work some reason :-(
Username: Hay88
Post Number: 978
TC284 = 1724 how to enter if still not work then check that number please.
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
Username: Gab9836
I`ve checked numbers again, it is TC289. Sorry my8, can You try it with this one please.
Username: Hay88
Post Number: 981
Gab9836
your code 1777
