13w7 Quick and simple question.
Username: Glowbox
Post Number: 23
Hey guys one last thing. I had the w7 with a 2.5 cubic foot box that we agreed was probably a little too big.
I recently traded the 12w7 for a 13w7 and was wondering if the 2.5 cubic foot box is good for that? JL recomends around 2.35 Cubic feet but i always hear manufactures specs don't sound great.
Long story short is a 13w7 good in a 2.5 cubic foot box tuned to 30hz?
Username: Glasswolf
Lexington, SC USA
Post Number: 13325
you can always reduce the box volume down to the 2.3 to 2.4 cu ft range by adding sand or MDF to the bottom of the box if you want to alter volume till you hit a sweet spot
Just remember you're also altering the tuned frequency by doing so
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 7660
another thing to remember is the actual sub displacement itself. not from the 12w7 to the 13w7 im not so certain how much then differ in actual displacement but your box size will be smaller by switching out the subs alone.
Username: Glowbox
Post Number: 24
Ya after sub and port displacement its 2,5. I'm just wondering of that is too small for a 13w7?
Username: Glowbox
Post Number: 25
Ok so i decided im starting from scratch and building a new box for the 13w7
- What volume (after port and sub displacement) would you guys recomend for a 13w7?
- And what tuning would you recomend for a 13w7?
I want to really hit the lows but not sacrifice too much output.
Username: 813thumper
Tampa, FL United States
Post Number: 159
2.3 cubes @ 32Hz
if you need a design i dont mind helping you out
Username: Glowbox
Post Number: 26
You dont think 2.3 is too small?
I was working with a few designes and possibly came up with 3 cubes @ 31hz. Would that be good or too big possibly free airing it?
Username: Dustin3
Box Designer & Builder...Dustin
Post Number: 5546
No, 2.3 wouldn't be too small. I would have it anywhere from 2.25-2.5 cubes and you will be fine. Let me know if you want a detailed design and cut-list. I can come up with it pretty quickly
Username: Glowbox
Post Number: 27
Thanks for the help and ive actually been designing a few different ones. haha.
So which would you prefer Bassman? 3 cubic feet or 2.5 cubic feet both tuned to 31hz for the best blend of SPL and SQ?
Username: Dustin3
Post Number: 5555
How much power will you be running Mike?
Username: Glowbox
Post Number: 28
1000 watts off a jl 1000 slash v2
Username: Glowbox
Post Number: 29
So i will be building the box this weekend and would really like to know if 2.5fft^3 or 3ft^3 would provide the best blend of SPL and SQ and if a good frequency is 31hz?
It will be recieving 1000 rms
Thanks so much!
Post Number: 161
2.5 i wouldnt go any bigger. and that 2.5 is accounting for port and sub disp.
Username: Glowbox
Post Number: 30
So just to be sure you think 2,5 after subtracting sun displacement and port volume?
And how does 32hz sound for that size?
Post Number: 163
yes 2.5 cubes net volume. if you would like me to design you a box i would be happy to. just give me your max dims. 32hz would be awesome man.
Username: Glowbox
Post Number: 31
I actually already got it designed and ill post pix when I'm done. Thanks so much!
Post Number: 164
cool dude. are you by any chance on the scikotics forums?
Username: Glowbox
Post Number: 32
haha yep i assume you are too?
Post Number: 165
haha yeah boiii. i recognized your username. what chapter are you part of?
Username: Glowbox
Post Number: 33
haha I'm from Minnesota. You in Florida?
Post Number: 166
yep part of the tampa chapter.
Username: C0hpl
Post Number: 14
HEY, NOT TO HIJACK THE THREAD OR ANYTHING.. BUT HOLD ON CAP LOKS.. okay there we go.. i also have a 13.5" W7.. and its currently in the jl audio pro wedge.. its a tiny little sealed box haha, i want to go ported so i can hit them LoWssss.. nawmean?
anyway.. could you guys send me the box designs you came up with please?
I currently have a kicker zx1500.1 and was wondering if that is an okay amp for me to use? my friend said i cant go above 1/4 gain or it will blow it...
what do you guys think?
thanks
and please PM me the designs..
One love
Username: C0hpl
Post Number: 15
HEY! Your in TAMPA?? Im in SARASOTA.. i could buy $$$ the box from you if u made me one...
Post Number: 167
yeah dude i will make you one. heres my email you can contact me there easier.
enzofreak224@aol.com
