Sub box specs
Username: Rosrock
Post Number: 74
ok so the adbcwarehouse guy says its tuned to 30 hz and 2.5 cu ft.(this is for an fi q 12) Id like you smart box guys to confirm this please.
here are the OUTER box specs of it.
27 inches wide, 14 inches tall, 16 inches front to back.
the port is 1.5 inches wide(from the inside of it.. all open space) and approximately 12.4 inches tall(again open space.. i didnt count any woodon top of the port or below, if u know what i mean im bad at describing). The port goes 18 inches straight into the box.(theres no L, just an I)
ok so id really appreciate what u guys can come up with thx a lot.
o yea and its 3 quarter mdf wood.
Username: Glasswolf
Lexington, SC USA
Post Number: 13363
http://www.diysubwoofers.org/prt/ported1.htm
Username: Glasswolf
Lexington, SC USA
Post Number: 13364
Oh also I would double the front baffle for the sub to 1.5"
Username: Dustin3
Box Designer & Builder...Dustin
Post Number: 5549
The box you have looks like it's tuned to 32 hz instead of 30hz (if there is no L in the port like you said) and is about 2.43 cubic feet before displacement. So your looking at around 2.3 cubes @ 32hz for the box you have.
Username: Dustin3
Post Number: 5550
I modeled it up with my program
Username: Rosrock
Post Number: 77
o greatbassman so... is there really that much of a difference ? what should i expect. thx a lot!
Username: Dustin3
Post Number: 5551
Nope, there won't be a huge difference and the Q sounds great @ 32hz anyway man. expect some nice lows out of it
Username: Rosrock
Post Number: 78
jaja thats what im hoping for ordering tomorrow!
Username: Rosrock
Post Number: 79
o god i cant wait till it arrives heard so many good things
Username: Rosrock
Post Number: 80
but so bassman if im poweing it with 1200 rms do u think ill need the spider option as well as the p chamfer option? what ya think
Username: Southernrebel
Post Number: 8024
If Bassman's #'s are right (didnt check, but i bet they are)...you are looking at less than 9sq inches of port area per cuft.
You might be looking at some pretty nasty port noise at 30-38hz.
Username: Rosrock
Post Number: 81
someone else confirm what hes saying?(as well as what that means)
Username: Dustin3
Post Number: 5552
^^ true, forgot to mention that. You will definently want a little more port area though like Canaan said..
Username: Rosrock
Post Number: 82
??? so what the hell can i do to change that? ur scaring me man.. suggestions?
Username: Dustin3
Post Number: 5553
Means that your port height/width ratio is not big enough so you need a bigger port. If the port was 2.5 - 2.75 inches, that would be alot better.
Username: Rosrock
Post Number: 83
so lets say i go back to the abc wahehouse guy.. what should i tell him EXACTLY be specific
Username: Rosrock
Post Number: 84
ur not saying i need a difference box.... are u? or what
Username: Dustin3
Post Number: 5554
Tell him that your port area is too small, and that 7 sq inches of port per cube is too little for a slot port. Yes you would need a different enclosure.
Post Number: 8025
Did you tell the box builder what sub you were getting? And what power you would have?
You see, if you were using a low powered sub...say 2-300w, you would be fine w/ that much port area. But w/ higher power, you will likely get chuffing (aka port noise). I would go for at least 12sq per cuft for port area, depending on the amount of power you are using.
Username: Dustin3
Post Number: 5557
Since you will be running 1200 you should look into getting a diff box, or you could try it out, and it if you get no port noise then your fine. But you most likely will.
Username: Rosrock
Post Number: 85
yes i told him EXACTLY which sub hed be making it for! so since he fucked up dont u think he should make me another free of charge!?
Post Number: 8027
Well, technically yes it is the builder/designers fault for not building it w/ enough port area. But sadly, ALOT of shops don't know any better, and even when they do get port noise, they blame it on the sub not their box. Some don't even know what port noise is.
I would go talk to the guy and ask him if he thinks you will get port noise. If he looks like he has no clue what that is, mount the sub in the box and show him that 'chuffing' sounds like. Then tell him its because of too little port area, get him to rebuild it w/ more port area, but the same tuning.
Username: Rosrock
Post Number: 86
sigh ok
Username: Rosrock
Post Number: 87
hey bassman could u give me a call maybe real quick 989-928-0083
