Advantages of using a slot port
Username: Slimdog53185
Bowling Green, Kentucky U.S.
Post Number: 133
What are the advantages of a slot port if any? I normally use round ports on my personal boxes but use slot ports on the ones I build for people. What is the difference between port shapes?
Username: Glasswolf
Lexington, SC USA
Post Number: 13380
typically slot-vented boxes will yield better SPL numbers while avoiding any port whistle issues, but at low volumes, the subs can lose a bit of their impact. Smaller round ports work a bit better at lower volumes. That's been my experience.
