Ouch
Username: Gcs8
Atlanta, Ga
Post Number: 415
i think i got owned by 2 l7's in another Camry to day. i think i need to go be emo.
Username: Bloodforge
Post Number: 49
Look at it this way, He will probably be replacing those L7's sooner than you will be replacing your subs, when they fail horribly. If that's the case you win, or atleast your wallet does.
Username: Gcs8
Atlanta, Ga
Post Number: 416
to be fair its 2 polk 12"s on 1500 watts at 2 ohms that i picked up for 64$ a peace......
Username: Southernrebel
Post Number: 8011
boohoo...a pair of $500each subs were louder than your $64 subs.
oh, wait, they are L7's...aren't they the king of all subs? No one can beat "dem soloz"
Username: Deadrabit
Marionville, MO
Post Number: 2394
the L7s are the loudest subs in the WORLD!
the only way u will win is if u get the jackhammer
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 16225
in this game there is always gonna be some1 who is louder than u ...
Username: Gcs8
Atlanta, Ga
Post Number: 417
well i know but his system was just getto as hell, and i have put a lot more time, blood, sweat, and money in to my set up.
Username: Glasswolf
Lexington, SC USA
Post Number: 13318
then be proud of that fact.
I've seen a lot of SPL vehicles that are nothing but gutted interiors, raw MDF, and bare wires laying all over the inside of the car. They look awful, but yeah, hitting 150+ dB at least, so very loud.
I just smile, and know that my installs look cleaner, and more professional, and yield a far better experience for doing what car audio is meant to do. Play music.
Username: Tejcurrent
Post Number: 2228
He was still louder
j/p
IVery few SPL setups are eye candy, and very few pretty installs get very loud from my experience anyway. Often it's just too much time and money to do both.
I was pretty set on just getting louder, but I'm trying to round things out a bit more, including improved aesthetics.
Username: Gcs8
Atlanta, Ga
Post Number: 426
yah i just need to spend more time with my system its going to be hard to get an sql car louder or as loud as an getto spl car.
Username: Rovin
Post Number: 16228
get ready to be spending alot of $ on this ...
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 13954
yeah for what you had and the other guy had I wouldnt feel so bad
Username: Gcs8
Atlanta, Ga
Post Number: 440
or the fact i just found out i was given bad math and was closer to 750 watts not 1500 Q_Q
Username: Glasswolf
Lexington, SC USA
Post Number: 13342
that depends on what you consider very loud, Troy. I think anything that can hit 140dB is more than loud enough for daily use, when it hits that number playing music, and not just burping one note.
