Kicker C18d box can it be ported ?
Username: Graiven
hi everybody i search the good cu/ft for a ported box . My subwoofer is a c18d i will do the port fb at 33hz but i search the cu/ft for the box .did anyone got it ?
Username: Glasswolf
Lexington, SC USA
Post Number: 13327
ported boxes are larger than sealed. you cannot just "port" a sealed box.
Username: Graiven
yes i know this but i want cubic feet for build the box in the correct size for a kicker c18d i know how to tune the port . But i dont know how cubic feet the kicker c18d take in a ported box . Did you know the cubic feet ? they dont say the cubic feet for a ported box in the manual .They only say the cubic feet for a sealed box . But me im looking for the cubic feet for a ported box .
Username: Glasswolf
Lexington, SC USA
Post Number: 13335
ported 18" sub?
8 cubic feet after sub and port displacement.
I'd tune the box low. 28Hz with a slot port if this was mine
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 13948
if they dont give the specs for ported maybe it wasnt built to be ported
Username: Glasswolf
Lexington, SC USA
Post Number: 13346
If you can supply me with the T/S specs, I can tell you if it will work ported or not, based on the Qts or EBP
