Like
1500 rms at 2 ohms or .5 ohms
Username: Dstokes
Monterey, California
Post Number: 52
Any amps you guys know put out 1500 or above at 2 ohms or .5 ohms?
Username: Jmartin2323
Cleveland, Ohio United States
Post Number: 7
do you have a particular budget? Any amp that will do the 1500 at 1ohm will do 1500 or more at .5 but it may not be recommended to run that amp at such a low impedance. contact manufacturer or check forums for running "blank" amp at .5 as for an amp at 2 ohms... once again your options are endless... view sites and specs and find something in your budget. but for .5 your gonna have temperature issues and possible damage.
Username: Sleste8
Shelbyville, MI United States
Post Number: 52
yeah man, .5 ohm gunna cost you more money. id'e stick with a good 1ohm stable amp.
and run it at no more, or no less
Username: Dstokes
Post Number: 56
I have a dual 1 ohm sub though
Username: Glasswolf
Columbia, SC USA
Post Number: 12660
There are plenty of amps that put out 1.5Kw @ 2 ohms.
Avoid trying to run at ultra-low loads like 0.5 ohms though, as this stresses any amp power supply and leaves very little reserve power for sudden demands in current and poutput. At least at 2 ohms, you'll have reserve power available in a good amplifier for those sudden bursts of output that a sub will require.
Username: Dstokes
Post Number: 57
so a alpine mrp2000 will be good?
Username: Poprocks
Post Number: 336
Yes Apine MRP2000 are good.
What sub(s) you have?
Username: Glasswolf
Columbia, SC USA
Post Number: 12745
a used Orion 2100HCCA will do 800WRMS x 2 @ 0.5 ohms, or 1600WRMS x 1 @ 1 ohm bridged... but it's going to require a LOT of current to do that (class AB amp) and it runs extremely hot.
Username: Rios4life
Fresno, CA United State...
http://www.lightav.com/car/amps/poweramps.html
i ran into this website a while back wen i was looking for an amp that can push 1000 watts at 2 ohm. its a list of all the best amps in order based on power output. there are amps that run at .5 ohms
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 7549
selling my saz1500ds.. they will handle 0.5ohm daily and put out more than 1500rms
300+ actual shipping
pics here - http://carstereoforum.net/showthread.php?t=4304
Facebook
Shop Related Deals
Directory
