Bypass codes for all brands!
Username: Ongtroiconluv
hey guys!! i've just open an audio shop!! i wonder if you guys can show me the bypass codes for all of the brands!! (etc. Clarion, Alpine, Pioneer) so we don't have to do the switch!! i already knew the code for Dual, Jensen!! thanks much if you guys can help me out!!! take care!
Username: Mateo1919
What is the code for dual?
put a movie in
1. Press STOP twice on the remote
2. Enter: 26604 on remote
3. Press ENTER
thats it!
Username: Aguita
jensen 9312?
Username: Tqg317
i second that on the vm9312, its obviously not the 1264 code
thanks in advance
-=TqG=-
Username: Tqg317
i second that on the VM9312, it is obviously not the 1.2.6.4 code or at least it wasn't the 300 times i tried thanks in advance
-=]TqG[=-
Username: 19chevy76
Spanaway, Washington s...
I third that one the vm9312.
Username: Gbiz044
Thank you. However there is no ENTER button on the remote for the vm9312. What button do I need to press at the end?
Username: Fadizzle03
Jackson, Michigan
will this work without a ground connected at all or does it need to be atleast hooked up to the parking brake because mine is not connected at all and does not work at all please let me know asap
Username: Brucecarter1
Phila, Pa
i was wondering if anybody know,s which wire,s i,m supposed to hook up on the brain of my kvt-717 to get it opperational and if i have to hook up a brake ground how do i bypass it
Username: Paparoo48
Austin, TX US of A
Are all the codes for the Dual brand the same? Apparently every can't come to a consensus on how to permanently unlock a Dual brand player. I have seen everyone talk about an 8181, but does anyone if the 26604 code works for a XDVD8183? I just got one and need a sure fire way to crack it open...
Username: Simona
CO USA
I am looking for the Clarion vrx775vd brake bypass code if any one can help.
Username: Draven1980
Carol stream, Illinois Usa
any codes for the UV7TS Jensen Phase Linear?
Username: Haring23
Gainesville, Ga Usa
how do u watch a movie while driving with the dual 8181
Username: Flash04
Vintondale, Pa Usa
does anyone know a code for Valor DVD players?
Username: Imkanguhit
what is the codes for Savant? Does anyone know?
Username: Masterfong
Miami, Fl Usa
i need the bypass code for XOD1730. anyone please
Username: Sp0rt4320
Cirtus Springs, FL US
HELPPPP!!!! I have a Dual 8181 and i tried to ground the parking brake wire to a screw and to the ground coming from the back of the unit... it worked both ways, but as soon as i put the car in gear the light say the parking brake is up stays on and starts beeping.... What am i doing wrong?
Username: Jjkeane1
Anyone got a multi region code for alpine iva w205 please help me its drivin me nuts
Username: Raidernation
San jose, Ca Usa
does anyone know how to brake bypass for the valor dds-650tw.......Please Help.............
Username: Aramo
Guys, My XDVD 700 that I just installed, has a flicker in the screen,,, I am assuming that this is a defectr? Could it be a lack or good enough ground?
Username: Griz_bear2001
Missoula, MT USA
HERES HOW TO BYPASS ON THE VM9312.
The parking brake bypass procedure:
1. Go into AM/FM mode
2. Hit "setup" on the remote control
3. Enter 543210 on the remote, listening for the beep for each number entered
4. A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5. Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
Username: Stateprop486
PA
Post Number: 800
JENSEN SUCKS!!!
Username: Slicebogey
This worked for me with every Jensen in dash DVD player I Installed so far:
JENSEN PARKING BRAKE BYPASS VM9311 , 9411, 9511TS , 9021T2
The code is a permanent way of disabling the brake override on the Jensen units.
How to by-pass video on Jensen in dash dvd units
First Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to view video while driving"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that blue screen.
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and that's it your done!
The other way of doing this is by not engaging the parking brake sequence, so you're inputting the code with out seeing it this is the moron way to do it because you cant see the options but the same instructions apply
Please use caution this code is being sold for store displays or show use only not responsible for misuse or use while driving . check local laws before bypassing parking brakes
Jensen 9312 by pass code!
The parking brake bypass procedure is as follows:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Username: Beriswybsj
Anyone got a multi region code for Sanyo dvd-hp58, thank you
Username: Cory_james
Clarion MAX385VD code please?!?!?!
Username: Psychedelic_feta
Montreal, Quebec Canada
Post Number: 55
Dwayne Stokes: I hope you're not hijacking my code and instructions! : ) That would be plagiarism.
State Property: Don't be a T*at...Fact is, this line of jensen radios blows a lot of high end units out of the water.
Psychedelic_feta: Ohhhh no of course not...lol
State Property: Don't hate...I have 3 vehicles and all with Jensen and they are still going strong
Username: Sm2008
help bypass brake thing on jvc JVC KWAVX710, or what codes work for jvc.
Username: Eliz483th254
can anyone help with a bypass code for the jensen vm9212? greatly appreciated!
Username: Tysci
bypasss for VM9020TS jensen please
earlier jensen post should work with the following jensen models VM9311, VM9512, VM9412, VM9411, VM9312, VM9511TS, VM9021TS and VM9022 and the phase linear UV8 and UV7 models
Username: Caldeira
Orlando, Florida Us
can anyone help with a bypass code for DUAL XDVDN8190
Username: Caldeira
Orlando, Florida Us
can anyone help with a bypass code for Dual xdvdn8190
Username: Jjherrera
I am looking for the bypass code for any kenwood or pioneer dvd car audio players
Username: Kingd
i have a dual xdvd 8181 and i can't seem to bypass the parking break. can anyone walk me through how to ground the ebrake wire?
Posted by dawit derege
Video bypass for dual in dash 8181
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
FACTORY RESET METHOD (not permanent)
1 Go to the Menu
2 Get to the Settings Menu
3 Select <yes> to Reset to Factory Settings.
Have recently heard complaints of this method not being permanent, as this is needed whenever they want to watch a DVD. Also, radio and screen angle presets are lost.
METHOD 2
AUDIO CD METHOD (Permanent)
1 Insert Audio CD
2 Press PLAY
3 Press STOP twice on remote
4 Enter 26604 on remote
5 Press ENTER
6 Take out Audio CD and Insert a DVD
METHOD 3
DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Press STOP twice on remote
** Enter 26604
** Press ENTER
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
The 3rd method seems to work with most of the duals
This info is only to be used off road/ display or show use don't be stupid and drive while watching a dvd
Username: Ruca1972
Help
I need the by pass code for the Jensen VM8013HD DVD Receiver.
Username: Ruca1972
I posted a month ago and still have not found a by pass code for the Jensen VM8013HD.......hopefully someone can help me out......thanks
Username: Juandongs
Please I really need some help me in this question, ...Will someone tell me the VIDEO LOCK BYPASS SWITCH CODE for my PHASE LINEAR UV8020 and how to do it......I see all the codes in this post related to other versions, but I need one for mine, I will really appreciate your help.......
Username: Mudboginking
what is the bypass code for the jensen vm9413.
Username: Omegaballa
Any one with code or bypass code for clarion pu-9836A as i cant find neither serial number nor any other label. Regards and thanks in advance.
Username: Ruca1972
I guess no one out there has the code for this player Jensen VM8013HD DVD Receiver.
Would really appreciate the help. Thanks
Username: Jaymac00comcastnet
Berlin, Nj United states
bYPASS CODE FOR pYLE pld7mu
Username: Rj1078
What is the code for the VM9413??????
Username: Brenden820
New Hampshire
I have a Dual XDVD8130 and Im trying to bypass the parking brake switch for watching DVD's.. I understand the 26604 sequence, but my remote doesnt have a "enter" button... What button do i press then?
Any help would be great!
Brenden820@yahoo.com
New Hampshire
Sorry, its an 8183
Username: Jjwitty
enter button is ok button also on the dual. but the code should enter once you hit the last number of the code.
Username: Stathos
can anyone help with the code for region of kenwood 8220 ?
thank you
Username: Joker8090
i need the code to a dp video dp311x multimedia system plz
Username: Jvitalis40
I have a absolute DD858 IN DASH... and I need a code real bad.. PLEASE
Username: Ville94
Florida United States
Is there a code for Clarion VX309? Or whats a trick to make everything work, in or outta gear... Thanks!
Username: Adam_wingert
Chambersburg, Pa USA
Phase Linear UV8020 bypass is very easy. When you are wiring it up, just twist the pink parking brake wire with the black ground wire and hook it into your wiring harness, that's it. You ground out the parking brake wire which tricks the unit into thinking that the parking brake is always on. No codes work that I have found and this is way easier and works perfect.
Username: Fireguy63
Does anyone have the bypass code and procedure for the new Dual XDVDN9131?
Username: Idk
Toledo
Does anyone know the bypass for
PYLE. PLD44MUB I've been all over for 2 months straight trying to
find it no luck AT ALL.can somebody PLEASE help me out???thank u A TON n advance
Username: 007exp
you want the code for all units?? GROUND THE PINK WIRE OUT!!!! THE PARK BRAKE SWITCH IS A GROUND< SO JUST HOOK IT TOO A GROUND. no need for a switch, or bypass code. lol
Username: Idk
Toledo
I'm trying the easiest way possible. I had best buy install so if I unhook the e brake wire then they will hit me with the (we didn't do this so your warranty is not any good now)B.S. But anyway that's y I'm looking for just a bypass code. Thank for the response
Username: Alopecito
How I'm supposed to BYPASS for DP311x
Thanks!!
