My new system
Username: Will2109
hey guys i have been building my own car audio systems for the last seven years and i would like your opinions on my next one. i have an 08 silverado 1500 ext. cab. i guess i am doing things backwards this time. i got a deal on a jl hd 750.1 amp, an now i am tryn to figure out what speakers i want. i normally only use kicker speakers and i have use almost all of their speakers. this time i would like to try out jl subs. it will either be 10 or 12 inch speakers, one or two. in a ported box ethier under seat or in a regular rectangular box. what i am really curious is what do you all think is the best speaker combo for the amp, and how good would yall rate the jl hd 750.1 amp. thank you.
Username: Skdooley
Roanoke, VA Usa
Post Number: 163
JLs will be a nice step up from the Kicker woofers. Good choice. I'd say the W3's may be what you're looking for.
Username: Nick_belsky
North Canton, Ohio USA
Post Number: 132
W3s are a great match with that cab. Keep them in a sealed box and you'll have nice, tight, clean bass with that JL amp.
Username: Armykyle1
Ms Us
Post Number: 874
Or two Diamond D1s. Do a center console box
Username: Will2109
I was thinking about going with either 1 or 2 jl w6 with them being either 10's or 12's. Which ever would be the best combo for the amp. I was also wondering if the jl hd 750.1 amp pushes more power than the 750 rms watts that is rated for.
Username: Armykyle1
Ms Us
Post Number: 878
If you had a 1000 I'd say W6s but you'd be under powering them. There's more out there than JL too
Username: Will2109
I know their is alot more out there than jl, but i have always owned kicker and the only other brands that i worked with and liked is jl and digital design so these are the bands i know and i want to go with jl.
Username: Will2109
I think i will probably go with a w6.
