Gold Member Username: Cplaya280Pennsylvania USA Post Number: 1001 Registered: Oct-05 | I need some new front and rear speakers right now I have stock speakers in a 2000 chrysler concorde and my system I have a AQ2200D and a 15" Audiopulse Revo and the bass is so loud and deep i can barly hear the vocals coming out of my speakers So was wondering what are some decent speakers that you can hear the vocals nicely or at least better. I used to have MB Quarts in my old vehicles but the vocals was way to high pitched for me so any other good vocal speakers i was thinking of Infinity Kappa's but wanted to know if there was better. My price range is $60-$100 for front speakers and the same goes for back speakers $60-$100 I don't really want to run another amp at the moment for components so anything thats pretty good |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15750 Registered: Jul-05 | look for DLS on ebay .... |
Gold Member Username: Cplaya280Pennsylvania USA Post Number: 1002 Registered: Oct-05 | i see DLS 6x9 speakers on ebay for $125 which i would probably use for the rear speakers but what are some good front speakers around the same price or cheaper that would sound good even without an Amp |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15752 Registered: Jul-05 | but y wud u want speakers without a amp when u have to hear those among 2200wrms of bass ....a front stage is more important than rear speakers which u can still have if u want but dont skimp on the front speakers .... |
Gold Member Username: Cplaya280Pennsylvania USA Post Number: 1003 Registered: Oct-05 | yes very true but it my previous vehicle i could hear the vocals pretty good and they was stock, so maybe its just my vehicle now the speakers are just really weak. what about 6.5 front speakers CDT,Alpine type R or S, or Infinity Kappas or any others since they all cost about the same price on ebay |
Gold Member Username: Van_manBoston South, MA Post Number: 5105 Registered: Mar-06 | Front http://http://cgi.ebay.com/BEYMA-RF652-2-way-Speaker_W0QQitemZ140290431744QQcmdZ ViewItemQQptZCar_Speakers?hash=item20a9f61b00 Rear http://cgi.ebay.com/BEYMA-RF652-2-way-Speaker_W0QQitemZ140290431744QQcmdZViewIte mQQptZCar_Speakers?hash=item20a9f61b00 Or same front rear set up with these. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-542&FTR=Eminence%20LA6-CBMR&CFID=5029023&CFTOKEN=10949921 |
Silver Member Username: SkdooleyRoanoke, VA Usa Post Number: 151 Registered: Oct-09 | You're going to need an amp on your speakers for them to have enough output to make a difference. Upgrading your speakers will make them sound better but they'll still only get as loud as your deck can make them get. Go with a nice component set for the front. |
Gold Member Username: Cplaya280Pennsylvania USA Post Number: 1005 Registered: Oct-05 | alright lets say i'll eventually get an amp for my speakers but dont want component set at the moment what is something good to start off with until i decide i wanna upgrade to an amp. Any speakers with louder vocals more so then bass. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10832 Registered: Jul-06 | As mentioned already, you're not going to get what you want with just coax speakers run off the HU. A good component set for the front and an amp will do the job.... rear speakers are not needed. Focus your money/attention on choosing some components and an amp. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12921 Registered: Jun-04 | x2 |
