I need a amp for 2 hccas
Username: Biggmatt714
somebody help me. does anyone know a good amp to push 2 orion hcca 10s? any suggestions
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 15415
sub model no & budget ? ...
they are the hcca 10.4. i need an amp that will push these at 1 ohm. i was wanting to stay under 700 for the amp is possible
Username: Tbone198515
Crawfordsville, Indian USA
Boss Audio OL5KD
5000W Class D Monoblock Power Amplifier With Remote Subwoofer Level Control
Max power @ 1-Ohm: 5000W x 1
Max power @ 2-Ohm: 3500w x 1
Max power @ 4-Ohm: 2250w x 1
Remote subwoofer level control
RCA line outputs
Gain control
Input sensitivity selector
Variable subsonic filter
Strapping capability: Strap two amps together for twice the power
Variable low pass crossovers
0 - +18 dB Bass Boost
Power and protection LEDs
0--180 degrees Variable phase shift control
Signal-to-noise ratio: > 100 dB
THD: 0.01%
Dimensions: 11-5/16"W X 2-5/8"H X 17-1/8"L
runs arround 500$
