Good amp for alpine r type
Username: Wackzirth88
K-town, Il U.S.
Post Number: 25
i jus got my girlfriend a sub for her car. i got her one alpine r type. its 2 ohm and i think 500 rms. what would be a good amp for that?
Username: Prozack52
Cincinnati, 2-audio puls...
Post Number: 537
anything that will put out 500 wrms at 1 or 4 ohms theres lots of amps out there man
Username: Kingandsons07
TEAM REVOLUTION Lincoln,NE
Post Number: 558
get an amp puttin out 1000rms clean and wire it to 4ohms or 1ohm and set the gain right
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2587
^ I wouldn't do that. Get something 500-600w @ 1 ohm to be safe (so long as it has Dual 2 ohm coils).
Top of my head Orion/ Directed/ Dei D1200
http://www.sonicelectronix.com/item_7560_Orion+HCCA-D1200.html?utm_source=froogl e&utm_medium=organic&utm_campaign=froogle
Check out ebay as well.
K-town, Il U.S.
Post Number: 29
it was a used a r type i got my money back cuz when i hooked it up it sounded like sh1t at higher volumes. i turned my amp down and everything it jus sounded like sh1t. but another guy in town is selling his two 15" mtx 4500s for 50 bucks. if they sound right ima pick those up
Username: Insearchofbass
Post Number: 11416
Sounds like the enclosure it was in may have been at fault.
Username: Rovin
1 15 = 149.5 DBs ...Trinidad & T...
Post Number: 14955
^agreed - especially if in a high tuned box it will sound like crap
id rec a 600-700wrms amp ...
