Audiocontrols/EQ - Question's
Username: Mixmastaspig
Team RD, Canada
Post Number: 2020
For my new set up I'm looking for an EQ of sorts and seeing as how I have never actually owned one yet I have NO CLUE as to what I need to look for....just for a 4 channel amp and a sub amp...
Basically just looking for tips and info on a decent EQ. I like the idea of being able to save your setting so you can change between then on the fly.
Any tips?
Thanks!
Username: Rovin
1 15 = 149.5 DBs ...Trinidad & T...
Post Number: 14937
best shud be the ac DQXS
each ac model has specific input\outputs freqs so take note of that
never really had use of a external EQ since my premier 860 has 13 band EQ ...new 880\800 has a 16band L\R EQ ...
Team RD, Canada
Post Number: 2021
Hrmmm well I Just bought the AVH-P4100DVD about a month ago and I'm pretty sure I only have a 3-band EQ.....lol
Username: Rovin
Post Number: 14940
wow a 3 band must suck ...
the 3 input \ 3 output EQS might be what ur looking for ...
Team RD, Canada
Post Number: 2022
It's............. ok.......lol I'm just digging the whole double din set up!
I will look into those models, just don't want to pay an arm and a leg for em should have nabbed that one someone was selling on here a while back.
Username: Nd4spd18
Philadelphia, PA
Post Number: 10376
EQ settings are not meant to be changed on the fly... theyre supposed to be set and forget. But audiocontrol is about as good as it gets and the digital models might be what youre looking for.
