System Turns Off
Username: Lanedub11
I have a problem when I turn my system up too loud it just turns off. The whole system resets its not just one thing its everything. Anyone know why?
Username: Insearchofbass
Post Number: 11409
Your voltage is dropping to much from not having enough alternator and when that happens it will do what you described.
Username: Lanedub11
Post Number: 7
So brand new alternator? or is there a cheaper alternative?
Username: Lanedub11
Post Number: 8
Username: Stateprop486
Phnom Penh Cambodia
Post Number: 1786
first what all are you running? also what all is turning off? just your amp and subs or you mean like hu and stuff too?
Username: Mike11202
RE MT 15 VFL 200.1 , Sewell, NJ US
Post Number: 1898
are you running stock battery? many stock batteries just barely start the car
Username: Lanedub11
Post Number: 9
i got head unit, 2 infinity 5.25, 2 infinity 6x9s, 2 type Rs running off a 500w Alpine mono amp.
Username: Lanedub11
Post Number: 10
stock battery
Phnom Penh Cambodia
Post Number: 1787
500 watts should be fine on a stock alt, prob got a loose wire somewhere. recheck your wiring.
Username: Lanedub11
Post Number: 11
Alright will do
Phnom Penh Cambodia
Post Number: 1788
also check you gain, even tho that shouldn't be the problem considering its only 500 watts as you stated.
Username: Mike11202
Post Number: 1899
try doing Big 3
my friends car does the same thing.. he has the exact same car as me but i have a yellowtop and big 3 and no problems here.. used to have HO alt but dont need it anymore since im running under 1,000 watts
Username: Lanedub11
Post Number: 12
if i upgrade to a 1000w amp will i need a new battery?
Username: Lanedub11
Post Number: 13
what is the big 3?
Phnom Penh Cambodia
Post Number: 1789
possibly, depending on how old your battery is it may need to be replaced right now. I was running 1000 watts in my old car fine, no problems. also big 3 wouldn't do much considering you aren't running a H/O alt.
Username: Lanedub11
Post Number: 14
i have a 94 cadillac and it has a little over a year old interstate battery in it
Username: Mike11202
Post Number: 1900
alternator to (+) battery, battery (-) to chassis, engine ground to chassis
Username: Mpinto19k
Dallas/Fort Hood, Tx
Post Number: 128
What Mike just said is the Big 3 and my friend had the sammmme problem and all he has is a 500watt amp but a shity battery. He changed his battery and everything was fine afterwards.
