Subwoofer wiring?
Username: 71_chevelle
Post Number: 212
Ok might sound like a dumb question but i was wondering is it possible to wire together a dual 1 ohm sub and two dual two ohms subs in parallel? this would equal 1 ohm correct? or is it bad to mix different ohm subs together?
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 3126
do not do mix v.c impedence on same amp... the subs will see different power from the amp.
Username: Hittin1
Post Number: 3127
i need to clarify.. you can on multiple channel amps, but never on same channel
Post Number: 213
Oh i see that makes sense!
so would it be best to go with 3 separate mono block amps one for each sub? or just wire 3 dual 2 ohm subs down to 1.33 ohms and call it good if one was trying to get the best out of the subs or is 3 dual 1 ohm subs better at .667 ohms, both wired parallel to a 1 ohm stable mono block amp?
