Awesome Infinity deal for retail employees
Username: Latitude
Manassas, Va USA
Hi,
I work for Bestbuy and saw an accomodaition going on from infinity.
They verify your employement with HR department.
How would you rate these speakers? I have a 2004 honda accord coupe with factory navigation. Looking to upgrade all 4 speakers and adding a subwoofer. Would you buy these infinity speakers and sub at the discounted price? or would you go for something else?
also what would be the perfect combination for speakers + sub + amp.
Thanks,
Infinity
REF1220DE
Dual 12" (300mm) Preloaded Enclosure with Slipstream Port
$168.00
2:
Infinity
KAPPA FIVE
Five-Channel Class-D System Amplifier
$192.15
3:
Infinity
KAPPA ONE
800 Watt Class-D Mono Subwoofer Amplifier
$172.90
4:
Infinity
REF5350A
5-Channel Complete System Amplifier
$147.00
5:
Infinity
KAPPA PERFECT 6.1
6-1/2" Component System
$144.20
6:
Infinity
REF1600A
600-Watt mono Subwoofer Amplifier
$126.00
7:
Infinity
REF1220SE
Single 12" (300mm) Preloaded Enclosure with Slipstream Port
$105.00
8:
Infinity
KAPPA PERFECT 10DVQ
10" Die-cast subwoofer
$91.87
9:
Infinity
KAPPA680.9CS
6" x 8" (5" x 7") two-way component system
$72.12
10:
Infinity
KAPPA692.9I
6" x 9" 2-way car audio loudspeaker
$46.86
11:
Infinity
KAPPA60.9CS
6-1/2" two-way component system
$72.12
12:
Infinity
6000M
Wakeboard Tower Speakers including multi-mount bracket system.
13:
Infinity
KAPPA ONE
$172.90
Username: Nd4spd18
Philadelphia, PA
Post Number: 10214
Infinity speakers suck..... their amps and subs are ok.
