Figuring out something??
Username: Semperfi
Post Number: 144
if i hook up a second battery to my car, how would i go about connecting it to the Alt, and the other battery (if i do that) the second bat will be going in the trunk and probably be a kinetik.
if i got a second higher up battery, will i still need to get an HO alt? how would i do the big 3? would i need to up grade the other battery or could i keep that a stock one?
i have another one but i can't think of it right now...
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2672
good! whew.
lol j/k
http://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1
http://www.the12volt.com/installbay/forum_posts.asp?TID=34399&KW=Dragorus
Username: Deadrabit
Marionville, MO
Post Number: 1339
yay mark
Username: Nd4spd18
Philadelphia, PA
Post Number: 10064
Yes you still need a bigger alternator if you're going to run a lot of power. And it's a lot easier just to replace your stock battery with a good one and you avoid the problems or running different batteries together.
Username: Semperfi
Post Number: 145
will i damage my amp if i hook up a switch to the remote wire on the amp to turn the amp on and off?
Username: Hittin1
Post Number: 2700
not at all
