DVC hook up - bridge, or channel per voice coil?
nels
Hi, I was wondering if you have a dual voice coil sub, and a 2 channel amp, would it be louder if you wired one channel to one coil, or just run it bridged. a specific example would be an alpine type R pushed by an alpine 2/1 ch. mrv-t757. right now i have it bridged to the amp. (the sub is a dvc 2ohm/voice coil. it equals a 4 ohm load wired in series...the amp is rated at 4 ohms)what are the ups and downs of each of these wiring schemes? thank you.
HI I HAVE 2 HOLYWOOD EXCURSION SUBS THEY ARE 800 MAX 400 RMS DUAL VOICE COIL 4 OHM WHAT IS THE BEST WAY TO HOOK THEM UP THE AMP THAT I AM USING IS A KENWOOD 7201 800 MAX 2CH I THINK THAT THEY ARE RUNNING IN SERIES IS THIS BEST
