What amp should i use for 2 kickers 15"s 500 watts each?
i have two kickers comp vr 15"s 500watts each. but i dont know what amp to buy the speakers say something about 8ohms but i dont really know about speakers so i would really like your opinion if you would tell me what amp would be good for these two speakers from the price around 100 to 250 dollars
John A
for about $260 on ikesound.com you can get a jbl 1200.1. then you would be pushing 600 watts to each sub. just turn the gains down a bit to keep from overpowering the subs. finding a 1000 watt amp for 250 or less will be hard to find unless you buy a used one
JBL bp1200.1 is the way to go!
