Component Speakers
Username: Ducka
Houghton/Hancock while..., MI United States
Post Number: 488
Hey guys, I've been thinking about getting some component speakers lately, but I havnt seen any that will fit my car(Olds Alero). I wanna put them in the same place as the stock speakers(4x6 and some 1"(I think) tweeters). I dont want to make pods for the speakers because I dont have experience with fiberglass and I dont want to do any permanent modifications to my car. I wouldnt be opposed to building a custom component set with parts from like partsexpress, but I would need some instructions on how to build a well tuned component system.
So if anyone has any suggestions for me that would be great.
Ohh yeah. My budget is no more than $150.
Username: Snowball123
West Allis, WI United States
Post Number: 1213
i say some diamond audio hex's. They're like 189, which isn't bad at all.Or go with some D6's. And you can also buy adapters for your car to make it fit whatever size you want.
Username: Ducka
Post Number: 489
Where can I get those speakers and the adapters?
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2281
You will not fit anything bigger than a 4 or 4x6 component in the door of an olds alero. The mounting depth is EXTREMELY shallow. Also, the molding of the door gets in the way for anything over that size.
The only way to fit a nice component set in will be to build pods. Believe me, I have tried every other way lol.
Post Number: 1214
5 1/4"
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=11753
6 1/2"
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=11755
And the adapters...
http://www.sonicelectronix.com/cat_i171_adapter-brackets.html
Don't know if your car is in there, but i think you could just google it and it might pop up.
Username: Ducka
Post Number: 490
Is there a way I can build an easily removable pod?
Username: Tatonka
Post Number: 2282
Mine is removable. It is bolted onto the door.
It isn't hard to fiberglass. I have step by step tutorials with pics of how I did mine.
Username: Ducka
Post Number: 491
Is it expensive to do? Like will it cost less than buying a Q-Logic pod? If so please send the tutorial.
Username: Tatonka
Post Number: 2283
Id have to explain it all over to you through AIM.
It isn't too expensive. Maybe like $60?
1 gallon of resin, a few years of mat, some body filler and filler primer.
Username: Ducka
Post Number: 492
Well that sounds pretty good. Do you think I could make kickpannels rather than door pannels? Also I probably wont be doin this for a while, but I'll let you know when Im getting ready to start.
Username: Tatonka
Post Number: 2284
Kickpanels are pretty much a no-go.
Go sit in your car like you usually would. You'll see that we don't have much leg room as it is. There really isn't a place to put kickpanels that won't get in the way.
Username: Ducka
Post Number: 494
http://www.qlogicenclosures.com/c-3505-ql-k1013.aspx
What about like these?
Username: Tatonka
Post Number: 2285
You wont have any leg room. In the alero, they aren't tucked away like that lol.
Username: Ducka
Post Number: 496
Shiiiiit. Looks like Im gunna be using door pods... Did you mount your tweeters using the stock tweeter locations?
Username: Nd4spd18
Northwest PA
Post Number: 8501
I had the same issue with my blazer. No mounting depth whatsoever in the door, it didn't even have speakers in the doors to begin with.
Had to build enclosures. Mine are MDf though, not the best cosmetics but you can't make a better enclosure.
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2725
Pods are the way to go. It really isn't that hard.
Username: Ducka
Post Number: 497
how did you mount the mdf enclosure? Is it permanent?
Username: Tatonka
Post Number: 2286
You wont be able to mount a flat MDF enclosure on our doors lol. Too many curves.
Username: Nd4spd18
Northwest PA
Post Number: 8502
L brackets and screws to mount it, worked great.
On my doors the metal frame is relatively flat though.
Username: Ducka
Post Number: 498
lol yeaaaaahhhh forgot about that one...
