Like
RFR 3110
Username: Cheetah
Marion , Iowa
I AM GOING TO RUN 4 OF THESE IN MY BOAT AND WONDERING IF ANY ONE ELSE OUT THERE HAS THESE SUBS. i HAVE A 1501BD AMP DO YOU THINK THAT IS ENOUGH POWER FOR 4 OR 2? ALSO IF YOU HAVE USED THEM SHOULD I RUN THEM PORTED OR SEALED?
Username: Davids2004
Houston, TX USA
Post Number: 67
I would do 4 rfd2210 hx2 dvc 4 ohm and wire them at 2 ohms and give each sub around 350 rms. Port those badboys.
Username: Cheetah
Marion , Iowa
Post Number: 7
I ALREADY HAVE THE SUBS SO NEED TO MAKE DUE WITH WHAT I HAVE. ANY HELP?
Houston, TX USA
Post Number: 70
Well if you get another amp you will need two more subs. The hx2 are cheaper so I would sale those two subs you got and get 4 of the reg hx2. I wouldnt run that amp at 1 ohm myself.
Here you go.
2 Power HX2-150.00-200.00
BD1500-300.00-400.00
600.00 this way
Or
Sale Power HX2-150.00 a piece or more
That will give you at least 300.00
4 HX2-100.00 a piece=400.00.
100.00 this way.
So thats the deal there. Save money sale those subs and buy the 4 hx2.
Username: Cheetah
Marion , Iowa
Post Number: 8
THE PROBLEM IS I ALRADY OWN 4 SUBS. IN MY BOAT THEY ARE UNDER THE SEATS AND ARE GOING TO FACE RIGHT UP IN TO THE OPEN AIR WHEN I MOVE THE SEAT AWAY. tHIS IS A DECK BOAT AND I WANT ALOT OF SOUND. tHATS Y I PURCHASED THEM.
Houston, TX USA
Post Number: 71
So you alrady own the 4 power hx2? If so get another bd1500.
Facebook
Shop Related Deals
Directory
