Kx 350.4
Username: Chevelle
Lancaster, Pa Usa
Post Number: 77
What do you guys think of a kx 350.4 kicker amp.
Username: Nd4spd18
Northwest PA
Post Number: 8256
All kicker amps are very good quality and do rated power.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5461
good purchase
Username: Chevelle
Lancaster, Pa Usa
Post Number: 80
ok now compared to a punch 450.4 channel i have both
Username: Cd5honda96
OR United States
Post Number: 112
? ..so you have both and just want to know which is better?
What are you powering with them?
Username: Chevelle
Lancaster, Pa Usa
Post Number: 81
front door speakers and a L5 kicker
OR United States
Post Number: 113
How well do you like your L5 do on the 4 channel? dose the L5 have enough out put for you with just the 450?
Username: Chevelle
Lancaster, Pa Usa
Post Number: 82
it will bang just wanted to know as far as both amps which would be the better to run.I heard the kx.350.4 are powerful didn't hear to much about the fosgate
OR United States
Post Number: 114
I can say that the Kicker is pretty good good because I have the same one and they are underrated a little bit( I think the birth sheet on mine is like 402 or 412 not positive tho) , but I cant say much about the punch I have not seen any that I can think of.
Username: Chevelle
Lancaster, Pa Usa
Post Number: 83
What speaker set-up do you have
OR United States
Post Number: 116
kicker ds 61/2 front and 6x9 rear but I'm checking into prices for CDT and diamond some time in the next week or two, and if I decide to get something new I'll see if I can get some adaptors to put the 61/2 I have now where the 6x9s are and see if I like it.
Are you going to grab a more efficient amp for your L5 or are you happy with the 4 channel for now ?
Username: Chevelle
Lancaster, Pa Usa
Post Number: 85
Dude this fosgate when it hits it moves my ranger.The kx.350.4 man it is nothing compared to the fosgate.Boooooooooooom I'll stick with the fosgate mayde it was the way they set up the kicker but for it to be loud i had to crank the HU up to 40 even 25 sounded like a stock HU at 5
Username: Chevelle
Lancaster, Pa Usa
Post Number: 86
It sounds like a 15 being slamed
Username: Drant19
DUB-C, TX
Post Number: 1103
then you didnt set the gain right man. i dont think you would hear a difference between the amps, the power is too close to really notice a diff.
remember to hear an audible differnce, you need twice the power!
Username: Chevelle
Lancaster, Pa Usa
Post Number: 88
Gain was to be set and what kicker is saying with a 2.2v outptut on my HU gain should be set at between 9:00 10:00 no more.I'm getting a different HU that has 5v output it will be a little cleaner
Username: Chevelle
Lancaster, Pa Usa
Post Number: 89
I can hear a difference in the amps the kicker for it to be loud i have to all most max the volume on the head unit.Also even at 30 not that loud and my speakers make a cracking sound.They don't do that with the fosgate and at 25 it is loud unless the amps needs fixed i don;t know
OR United States
Post Number: 122
Can I ask what new Hu you picked up?
Username: Chevelle
Lancaster, Pa Usa
Post Number: 90
panasonic CQ-700cu is the one i'm going to order
OR United States
Post Number: 124
That one doesn't look to bad, I love my clarion dxz775usb I have been think of changing up tho maybe after Christmas
Username: Chevelle
Lancaster, Pa Usa
Post Number: 97
nice HU. still try to get this gain set up on the 350.4 they say not to go past the 10:00.But the way it is i have to have the HU at 50 for it to be loud.Hooked it up in my other car but i don't know if i want to keep it in there.
