Rockford gosgate p3...
Username: Mattbone
Post Number: 11
I was wondering if it would be a good choice? I have heard some good and bad about them. I can get two ten p3's almost brand new for 300$, and i was wondering how good theey would fit in my 03 silverado sinlge cab. i also was wondering what would be the best amp to power them. I was thinking about a 1000. how much do the 1000 watt amps usually run.
i don need it to be the best quality but a fairly good one?
Username: Bonhamd
TC, MI USA
Post Number: 874
not a good deal at all
Username: Mattbone
Post Number: 12
they sell for 220 new ??
Username: Bonhamd
TC, MI USA
Post Number: 875
http://sonicelectronix.com/search.php?keyword=P3&condition=new&search_in=all&cat egory=39&manufacturer=13&min_price=&max_price=&action=search&show_description=1& show_thumbnails=1&Submit=Search+Now%21
Username: Mattbone
Post Number: 13
ohh dam haha
thanks
are they good subs?
Username: Bonhamd
TC, MI USA
Post Number: 876
never heard them - post your budget
are you looking for SQ, SQL, or SPL?
maybe an AQ1200D for the amp
Username: Mattbone
Post Number: 14
well i was going to try and getr subs for about 300-400 im getting two tens for my silverado. I forgot which ae which... lol
but im not sure on which i either want pure loudness or both but i want the to be as loud as possiple. and on an amp i dont want to have to spend over 5 or 600. my budget is not yet determined because im still saving and im gonig to piece it together. but id want to keep it at about 1000-1500
Username: Bonhamd
TC, MI USA
Post Number: 877
the AQ1200D is 1200 watts RMS and is $249 shipped
SQ = sound quality
SPL = loud
SQL = mixture of both
the subs you buy may depend on how much space you have
Username: Mattbone
Post Number: 15
Yes teh subs will depend on it. because i really want w7s but they wont fit. there is a deal somwhere my friends got taht is buy one get one free jbl 12s
im not sure what model they are 130$ but i really want tens.
I havent heard of a amp that is 1200 for taht cheap? My friends 1200 cost 900$
Username: Bonhamd
TC, MI USA
Post Number: 878
$900?
what kind of amp is that?
Username: Mattbone
Post Number: 16
its a jbl. and my friend said amps are usually about 100 for every 100 watts
Username: Bonhamd
TC, MI USA
Post Number: 879
JBL makes nice amps but $900 is a crazy price for that amp
Username: Mattbone
Post Number: 17
idk. thats just waht he said...
but i just want a system thats almost too loud lol. i know i have a small budget, but i want the loudest possible with out sounding like sh**
Username: Mattbone
Post Number: 18
I want to try and get at maybe 160 db or higher if possible? I have a friend who got 180 db out of his two tens supposivly. but he had aloot more are space than i do
Username: Cozce
Post Number: 136
Username: Ctmike
Ct.
Post Number: 6357
"I want to try and get at maybe 160 db or higher if possible? I have a friend who got 180 db out of his two tens supposivly. but he had aloot more are space than i do"
Username: Insearchofbass
Post Number: 9927
Your friend is not getting 180 db. The loudest spl measured in the world with the windows up on the dash is 180. something. And your not going to be hitting 160 db. You will probably hit in the low 140's with what your looking at sub wise. And the audioque 1200d does put out a true 1200 watts rms. They are a very respected company.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5408
Audioque 1200d+ FI BL= what you want
Username: Hittin1
Lake Charles, La. United States
Post Number: 759
if he's in the 180 range than I'm in the 190's lmfao
Username: Mattbone
Post Number: 20
thats what i was thinking haha, but i dont know all that much obviously... lol.
