Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 633 Registered: Jan-07 | So my battery died on me... and I'm about to buy a new one, any suggestions? my car is an Altima 05, 2.5S, 1 Fi Q 12" and a kicker 1000.1, I don't know what size the battery should be, so please some help |
Gold Member Username: Nd4spd18Northwest PA Post Number: 7826 Registered: Jul-06 | http://www.odysseybatteries.com/battery/pc1400_25.htm That will fit your car, and those batteries IMO are as good as it gets. A ton of power for the size, deep cycle capable, and fast discharge. |
Silver Member Username: KickermanPost Number: 225 Registered: May-06 | not to ? M.S. but how does the odyssey stack up to a powermaster battery |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 635 Registered: Jan-07 | thanks for the help, but I was hopping to keep it under 200, what about die hard platinum? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 7834 Registered: Jul-06 | Just a regular car battery, nowhere near the performance of the odyssey and not deep cycle capable. I would recommend a PC1200 which summitracing sells for $180. Thats the best deal I know of. http://store.summitracing.com/partdetail.asp?autofilter=1&part=ODY%2DPC1200&N=70 0+115&autoview=sku 1200 amps quick discharge and deep cycle |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 636 Registered: Jan-07 | thanks for the help |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13962 Registered: Jul-05 | oddessy optima kinetic stinger all r good batts ..... |
Gold Member Username: Nd4spd18Northwest PA Post Number: 7836 Registered: Jul-06 | I'd agree with that if you take out optima, they have no more power than regular batteries. Also note that stingers are Odyssey batteries with the stinger brand name put on them at usually sold at higher prices. |
Gold Member Username: HdubbTeam Revolution Post Number: 3798 Registered: Nov-04 | exidd makes a good inexspensive agm battery. the roadforce. i bought one local and it seems to spec out a little better then the deka |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 505 Registered: May-07 | svr audio series are a good batt also. |
