Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 2932 Registered: Jul-05 | Hey has anyone used 12v fans to keep there amps cool? Im looking at some right now but really dont know what i should do... AIM-jakeyplaysbass26 |
Diamond Member Username: BestmankindPost Number: 21488 Registered: Oct-05 | are the pc fans 12v? |
Bronze Member Username: The_modBANVILLEUSA Post Number: 33 Registered: Feb-08 | Yes, 12V fans work. I used to install them w/ Rockford A-series amps. You just wire them to a relay using the remote. A few other companies make fans. Stinger makes a thermostat also. |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 2934 Registered: Jul-05 | This site has pretty much every size to choose from... http://www.buyextras.com/dc12vfans.html Im thinking about using 2 2" to push the air and 2 2" to pull the air out. I need to draw up some pics tonight and then it should make sense. |
Bronze Member Username: The_modBANVILLEUSA Post Number: 35 Registered: Feb-08 | A few of those fans set up to push and pull air would do great. Just grab a relay and a switch for them, you will be fine. If you need more air-flow, Stinger makes a high flow fan. |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 2938 Registered: Jul-05 | Heres what im thinking... -The black rectangle "holes" will be covered with plexi and have the amps mounted to the car under. -The right fans will push air while the left will pull. -The frame (3/4mdf) will be in 2 pieces so i can pull one up to get to the amps. The second piece will be under the box so everything is the same height. |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 2941 Registered: Jul-05 | This is going to be impossible to explain without a drawing... but... when wiring a set of fans should i... Distro block to relay (87), HU to relay (86), ground to relay (87), fans to relay (30)...this is on the tyco relay (old bosch). |
Diamond Member Username: BestmankindPost Number: 21493 Registered: Oct-05 | good idea jake. |
Platinum Member Username: James1115Use a simple... Post Number: 10692 Registered: Dec-04 | you got it covered man! |
