Radio dieing with volume
Username: 248vista
I have a Sony radio that when put at more than 20% of its volume capacity will reset itself (turn off) and turn itself back on and will continue to do this until the volume is lowered and the headunit is reset.
Any ideas on what is causing this?
Username: Neyetmare
Post Number: 26
i had this same problem with my stock deck, i never figured out the exact solution but im pretty sure it was just it overheating.
Username: Kpa2727
Old Bridge, NJ USA !
Post Number: 1330
usual cause of it is your over taxing the radio. the radio is working so hard to push your speakers it's ether heating up or clipping the signal so bad to your speakers it shuts off to prevent damage. most of sonys car audio products = crap. so if your driving large speakers thats why, or you have a bad ground to the radio.
Username: 248vista
Keith,
How would i be able to tell if the ground is bad?
