Just bout a lil SQ stuff wat yall think
Username: Basebalz13
Moneta, Va Usa
Post Number: 483
just got a sponsorship with DYNAUDIO and 12 voltz for a 2-way 242gt component system!!!!!
Username: Nd4spd18
Northwest PA
Post Number: 7470
You is gonna have some good components my friend. Now make sure you install them right and you should have a good sounding system Upload
Moneta, Va Usa
Post Number: 484
eh seal up the doors and put the mid there, and just gotta find the correct spot for imaging for the tweeter correct? 7" mid FTW
Username: Nd4spd18
Northwest PA
Post Number: 7473
Well the second parts right. Using a door as an enclosure for the midbass is exactly what you don't want to do....... Build an enclosure for it into the door, MDF, fiberglass, anything strong and make sure it's sealed. Difference in madbass output will be amazing.
And 7" mid yikes..... thats gonna need a fairly big enclosure.
Moneta, Va Usa
Post Number: 485
yea i know thats why i was thinking the whole door, needs lik 1-1.5 cubes i believe
Username: Nd4spd18
Northwest PA
Post Number: 7476
Sealed enclosures are forgiving, you can go somewhat smaller and not lose much performance.
But you will never be able to completely seal a door. Especially the weatherstrip under the window, nothing you can do about that.
Username: Insearchofbass
Post Number: 9213
congrats man
Moneta, Va Usa
Post Number: 486
hmm you got a point, guess ill see what i can do about building some sort of fiberglass enclousre in the the actual door i got put in modified class so i can do all the modifying i want!!!!
Username: Nd4spd18
Northwest PA
Post Number: 7479
Then with enough time and money anythings possible. It will come down to how much work you want to put into it....... if you're gonna do SQ comp take your time and build a really good installation.
Moneta, Va Usa
Post Number: 488
yea i wanna build a great system, but the problem is i dont know how to get that much airspace with wat little room i got
Username: Nd4spd18
Northwest PA
Post Number: 7485
With mids, almost any enclosure is better than free air. Example:
Right now I have mids that specify a bit over 0.1 cu.ft. and I have them in about half that space, as that's all I could do. Midbass output is pretty decent for 5.25" speakers. They pretty much can't do below 200 hz well, but that is true of most speakers that size.
I'm sure they would be slightly better in a bit more airspace, but I don't think it would be a huge difference.
So what I'm getting at is, design the biggest enclosure you can and run with that. It probably won't be half bad.
Username: Frkkevin
Post Number: 5072
install is key, dynamat and nice wire.. don't skip the little things
SQ is expensive, be warned.. and you will probably change up your gear quite often.. i've learned this :-(
also what deck are you going to run? i'd seriously suggest the eclipse 7200mkII
i run the alpine cda-9887 with the imprint tuning kit.. its amazing but man that eclipse looks wicked :-)
Moneta, Va Usa
Post Number: 491
well i got all the sound deading covered already about 80 square foot per door, the far inside sheet metal, then inner part(where all the holes are on the door) and then the actual door panel all has plenty of deadner, the wires? what do you mean, and as far as the HU im uhh still working on that lol, im big big biggg into SPL and doing pretty good, but then for MECA i started competing for the best of best of show so now i gotta work on my SQ crap
Username: Nyyfan13
15 Mag USA
Post Number: 9613
Are you going the SQ route now instead of SPL or what bud?
Cause last night, you were about to buy 2 DD9515's and now your talking about SQ.
Regardless, congrats on the sponsorship bud. Hit me AIM later tonight
Username: Frkkevin
Post Number: 5073
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2706
"well i got all the sound deading covered already about 80 square foot per door, the far inside sheet metal, then inner part(where all the holes are on the door) and then the actual door panel all has plenty of deadner, the wires?"
So you did 8-10 layers of dampener per door? Must have some pretty big doors... I think i used 80-90sqft on all 4 of my doors.
Anyways, congrats on the speakers and put them in door or kick pods.
Moneta, Va Usa
Post Number: 497
no its 3 on each part of the door
Moneta, Va Usa
Post Number: 498
yea i know yanks haha, im doing both SQ and SPL hehe i have busy competitions
