Amp for type r
Username: Fritos2
Post Number: 12
Almani HA-750.2 2-channel 450rms watt at 4ohms. would this be good amp for a 12" type r alpine?
Username: Dirtrider125
Post Number: 135
if u need a amp to power it at 4 ohms i have a kicker kx450.2 for sale it will do 550 rms @ 4 ohms i have pics
Username: Drant19
DUB-C, TX
Post Number: 893
get a mono amp that does 800wmrs. is your sub a dual4ohm?
Username: Fritos2
Post Number: 13
u sure?? i looked it up and it says 150x2 at 4 ohms
Username: Fritos2
Post Number: 14
yes dual 4ohm. isnt it bad for the sub to overpower it?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5327
not if you set your amp properly. IMO you should get a kicker Zx 500.1
Username: Rovin
Post Number: 13739
type r can handle 700wrms easy so id get a amp like
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19319
Username: 420alldaylong
Post Number: 3566
I don't know sh!t about Almani products but if I was you I would get a good 500/700RMS @ 2ohm.
Always try to use mono d class amps for subs but 2 channel amps will work fine.(efficiency is the key)
Whats budget for amp?
Username: Fritos2
Post Number: 15
like under $200. would it be bad if amp is only 5-200hz? the type r goes to 500 or something like that
Username: Drant19
DUB-C, TX
Post Number: 902
your going to put your low pass filter at around 80hz.
Username: Fritos2
Post Number: 16
so u usually dont have any sub go over 200hz anyway or wat?
Username: Xeigh
Post Number: 12
I actually just recently bought a 12' Type r sub and i'm trying to pick the right amp for it. I was looking at the Alpine PDX-1.1000 amp i have the dual 4ohm version of the type r, I currently have a MRP-F450 amp for my speakers so i believe i need a cap for my car as well. I'm a bit new to car audio so any guidance would be much appreciated.
Username: Fritos2
Post Number: 17
i was wonderin also when about would u need a capacitor like 1000watts 900 700 ect. and does a capacitor actually matter and make a diff.
Username: Drant19
DUB-C, TX
Post Number: 910
Justin make your own thread.
adfasn: NO CAP, it wont help you at all. your sub shouldnt play anything over ~80hz, if your sub is a dual4ohm sub then get a kicker zx750.1 it will put 800rms to that sub and the type-r will love that much power.
Username: Juliob
Post Number: 5338
You will need a cap when you have a HO alternator, BIG 3, batteries etc. It's not as cool as you might think like HEY! let me put a cap and my problems are solved.. H3LL NO
Username: Drant19
DUB-C, TX
Post Number: 923
caps are only useful in the CORRECT set up! yours is not needing a cap.
but like i said earlier, if your sub is a dual4ohm, get the kicker zx750.1 OR something that will put 700-900rms @2ohm
