Pioneer Premier Settings
Username: Xfacta82
Post Number: 130
I have a pioneer premier HU. I was wondering if anyone had any suggestions for the settings I should set for it such as the HPF, etc. Thanks
Username: Kpa2727
Old Bridge, NJ USA !
Post Number: 1267
hpf roughly 100hz or 120hz, bass filter 80 hz. that should be fine it's what mine are at, you can tune anything higher or lower from there except bass leave that at 80hz. bass boost also don't use , not needed , sla i wouldn't go 1 or 2 higher if you need it if not leave it at 0. the rest of the settings you shouldn't need to touch.
Username: Xfacta82
Post Number: 131
Why do I need the hpf at 100? When I put it at that, the lower end seems to disappear and I dont get much bass and it seems drowned out. Also, what is sla? I have that setting but what does it control?
Username: Kpa2727
Post Number: 1268
a 100 to 120 on high pass helps remove bass from your speakers this is done if your running the speakers off a stereo amp not the headunit so u don't over tax your speakers with bass after all thats what a wooofers is for. sla is sound level audio that is used to boost your incoming signals sound and sould only be used for things that are lacking like aux input.
Username: Xfacta82
Post Number: 132
I do not have a subwoofer. I have cdt components running off a four channel amp and cdt 6 by 9's running off the hu in the back. So since I do not have a sub, what should I keep the hpf on?
Username: Kpa2727
Post Number: 1283
well at that point you probably will be fine to leave it off as long as it dosen't sound distorted your fine.
