Dd audio...need help.......
Username: Gothicstretch
Ohio
im looking to buy some dd subs and amp but cant find a dealer anywhere i live....is there a site online i can buy them at? ive tried searching but cant find anything...... or any advice on some other subs and amp combo to go with to hit some HIGH db numbers....i was looking at purchasing the 12"pioneer premier ts-w3001d4 with some power acoustic 4000watt mono d block amps and running the at 2 homs....looking to get into some spl comps and just not sure what to really go with...any advice and help would be great
Username: Joebruce
Mach5Audio M...
Post Number: 1996
email DD theres a link on their site
Username: Rovin
Post Number: 13620
so u already checked http://www.ddaudio.com/dd/default.asp ???
check out the other brands here
https://www.ecoustics.com/electronics/forum/car-audio/472940.html
Ohio
i went to there site and found that there is only 1 dealer with in 200 miles of me and they want to charge me over 2000 for a dd500 series i know dd is expensive but they not that expensive. especially ffor the 500 series. so i was wondering if there was a site that sels them online.
Username: Joebruce
Mach5Audio M...
Post Number: 1997
You can order them online through DD.com Email them for prices and payment info
Ohio
i emailed them twice and all i keep getting is a dealer find automated type of message lol if there isnt any other site to order from what are your takes on the pioneers and amp im also looking at?
Username: Redliner
Wilmington, Ma
Post Number: 4322
call them with the number on the site ask if you can order direct from them. Cause theres no dealer around you. They should have no problem with it since they use to do it all the time. Also why dont you find a used one online for cheaper
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 254
go with rd instead of dd
Username: Redliner
Wilmington, Ma
Post Number: 4324
why please tell me why
Ohio
where could i go online to buy them used or what not?
Username: Redliner
Wilmington, Ma
Post Number: 4328
soundpressure.com will have the most
Ohio
Post Number: 7
thanx ill check that out real quick
Username: Jkidder
Worlds gunna end, In 2012
Post Number: 3488
timmy, stfu
chris, visit soundpressure or ca.co/forums and got to the classified sections. they always have people selling dd. id bomb the shop that told you 2000 dollars for a dd 500 series. literally, id send a bomb to the shop.
the cisco kid
Diamond Member
Los Angeles, CA USA
Post Number: 20523
that is brutal cisco kid.
Ohio
Post Number: 8
thanx cisco. anyone know how much the Z series goes for on the 12s?
Username: Goodie_goop
Mid town, Texas U.S.
Post Number: 870
"anyone know how much the Z series goes for on the 12s?"
more then you are willing to pay
Username: Zacdavis
Beloit, Wi
Post Number: 1640
http://www.caraudio.com/forum/showthread.php?p=4454737#post4454737
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1595
