Like
99 s10 single cab sub size options
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 2045
what would fit in there.
Username: Kyle_lowe
Post Number: 896
try out those new re shallow mounts
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5513
if you don't have a bench (which i assume you do) you could fabricate a new center console fairly easily. even if you do have the bench then you could do some cutting and such and fabricate a center console for the sub. either that or go the easy route with shallow mounts. re's should be good as well as realm audio.
Username: Cblaze
Post Number: 2046
dont have a bench but u can do woodwork without one. i got a jigsawlol.i can build boxes.its not that hard.i wanna keep all the seat space.i know i could prolly get 2 re 8's behind there ported..was just wondering if anybody had the dimensions of room behind the seat.
Facebook
Shop Related Deals
Directory
