Help
Username: Tech36
Post Number: 9
hey i have a geo tracker and ive upgraded for about the 5th time and i have 2 15" audiobahns se from 2004, i was wonderin if anyone knew how many wats they can handle rms cause i found them at a local pawn shop and i was wonderin if a class d amp made a difference in the sound of a subwoofer at the moment i am powering just one of them with 400 watts at most and it pounds like a mofo and i was wondering what all i needed to do to make it shatter my front window if u know what i mean.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5501
i would recommend upgrading a 6th time.
Username: Chaunb3400
All he does is catch t..., Alabama U.S.
Post Number: 14170
^^Ditto
Username: Surferdude9371
Im BTL Bumpin
Post Number: 839
i agree upgrade but as far as what they can handle do you have the model number? or at least a pic of them so we can try to fig it out?
Post Number: 14172
I believe they are dvc4ohm 400rms drivers
Username: Tech36
Post Number: 10
ok well i cant do a pic of them so forget the speakers i guess, but does a class d amplifier make a difference instead of having a normal amplifier, idk i guess are ther advantages to a class d amplifier because they seem to cost way mor for the wattage and it looks like id have to wire it up for an 8 ohm load unless somebody knows otherwise.
