Good amp of brahma
a newbie to car audio named danny
which would be a better amp for a brahma 15 - a kicker 1200 or jbl 1200. the kicker says a produces 1200 watts a 1 ohm, can i run a single brahma a 1 ohm?
Username: Its_bacon12
Post Number: 630
if you have the money, go with the kicker and since brahmas are dual 2 ohm, you can wire the sub's VCs in paralell to get a 1 ohm load
dannyboy
would the jbl amp hit the brahma 15 hard because i seen it for $350 and i am trying to save a little money. i dont want hard but major spl so if the jbl cant live up to it, then ill switch. but the box im getting supposed to increase sub spl by 2
Username: Jonathan_f
GA USA
Post Number: 257
The JBL will be fine for the Brahma. It'll well put out the power the Brahma can take. You can find them cheaper than 350, look around online.
dannyboy
thanks man!
