Punch HE
Username: Daven
Post Number: 11
Thinking about getting a Punch HE sub, but i noticed it has 8 OHMS Impedance, would this creat any touble with most amps?
Username: Pat_l
Tucson, AZ USA
Post Number: 190
You can get HE in 4 ohms as well.
Username: Alpinepower
Post Number: 37
8 ohms would require a 4 channel bridged amp per sub, can it not also be wired for a lower impedance>
Username: Davids2004
Houston, TX USA
Post Number: 32
With the 8 ohm he you would be able to run both positive to positve and negative to negative and be able to use a 2 channel amp for a 4 ohm load.
Username: Jonathan_f
GA USA
Post Number: 273
If you get two 8 ohm subs, and wire them in parallel, it'll create a 4 ohm load. That works well if you plan to get a 2 channel amp and bridge it. If you plan to run a mono subwoofer amp, then you should get 2 4 ohm models to create a 2 ohm load, as that is what most mono amps are optimized for.
