Help in Amp choice for Type R
Raymond
What would the Best amp to get the hardest hitting bass from my 12" type r under 500 dollars? i had a Boss 1600 Watt amp but it didnt work cause the ground terminals were bad and cut out every 10 seconds. Thanks in advance for the input.
Username: Jiggaman3105
Post Number: 9
in my opinion and from experience, i would say that the best amp for you would be the JL 250/1. it will give u a gauranteed 250 continuous watts, and with minimal wiring problems.
Username: Its_bacon12
Post Number: 638
jbl bp300.1 would be a better choice - alot less $$ and puts out 300w rms at 2 or 1 ohm so it wont matter if your sub is dual 4 or 2 ohms
