Jensen 9311TS ipod Problem PLEASE HELP
Username: Anthony_34
I Have The Jensen 9311TS And I Have The J-Link Cable For My ipod Everything Is Hooked Up Right The Video Out On The Modual Is Hooked Up To The Headunit Video In, And The J-Link Cable Works, It Plays All My Music On The ipod, But When I Try To Play Videos It Says "use ipod to controll / select video and or photo media touch screen to return to this menu" Then I Have To Controll My ipod Manually Not From The Headunit, I Play a video The ipod Goes Into TV OUT Mode And Nothing Happens On The Screen Of My Head Unit! ( My ipod Is Set To TV OUT = On, Widescreen, NTSC, Fit To Screen = On, Caption = OFF) And I Touch The Screen Like It Says And Nothing Happens What Is Going On? And Before I Set my ipod Video Setting To TV OUT = On The Headunit Played The Music Part Of The Movie But No Video! Someone Please Help Me I Cant Figure This Out I Have Tried Everything i Think ....
Username: Tone602
Az
i think you have to loop the ipod....another words on the top of the ipod (where the headphone jack plug in) you need the a/v cable connecting to the little box of the a/v input of the head unit. then there should be a cable (jlink ?) that plugs from the hide away box to the bottom of the ipod. this is how i got my dual xdvd8183 to play videos from the ipod. hope this helps.
Username: Mandajo8
Anthony Crispe -
I think I've found the solution to your problem. I'm not sure how helpful it will be considering the head unit you have in your car but it might help explain a little. I am also having the same problem. The videos wont play on my Jensen 9311TS using my iPod nano 3rd Generation. But videos play just fine using an iPod Video 5th Gen.
So anyway for quite some time i've tried to figure out what the heck the problem is. This is what i've found out so far...
I found this discussion in an Apple forum... http://discussions.apple.com/thread.jspa?threadID=1153331
There you will read that Apple has created a universal dock because newer iPods are not compatible with the older "cords". I'm going to enclose a few other links that helped me understand exactly what they did. Hope this helps in some way.
http://docs.info.apple.com/article.html?artnum=300277
http://www.ilounge.com/index.php/reviews/entry/apple-universal-dock-2007/
