Kicker ZX200.4
Username: Kaprese
Walstonburg, NC USA
Post Number: 595
what up fellows I want to no if this amp can do more than it's rated power? and if so how much more.
100 x 2 @14.4v Bridged
It's a 4 channel amp so how much power would I be getting total I never used a kicker amp before
Username: Stateprop486
PA
Post Number: 1256
prob do more then rated power...i just got a zx250.2 and birthsheet says 351watts.. :-) kicker amps are good and give u the bang for ur bucks!
Username: Ctmike
Ct.
Post Number: 5924
why not just buy an amp that'll do the power you want/need instead? it'd be alot better than hoping an amp is underrated enough to get the power you really want.
Username: Hittin1
LakeCharles LA., La
Post Number: 114
I have an old school kicker zx460. that is a little powerhouse... I know that it does more that is rms rating... 180x2 2 ohm stereo.. it is also a 4 channel amp...
Username: Hittin1
LakeCharles LA., La
Post Number: 115
it has one of those removable subwoofer crossover modules.
