JL 10W7 and 500/1 amp
Username: Mathxew
Post Number: 9
My alternator can't handle much more than 500 watts, so anything more powerful is out of the question.(I don't want to have to add a HO alternator)
Is there anything that will sound better/ hit harder than this sub and amp, for the same, or less money?
Also if i go with this, is the manufacture ported box design the best overall design?
Username: 94_toy
Post Number: 184
how bigs ur alternator?? cause 500w rms isnt very much
Username: Skibum12189
Cleveland
Post Number: 2739
that would be a very very solid setup for a 500 rms 10 it will slam
Cleveland
Post Number: 2740
and yes if you get the High Output 10w7 that'd be your best bet, but if not, JL offers a free box design that offers you optimal performance
Username: Mathxew
Post Number: 12
there is a High Output 10w7 and a regular? what are the differences?
Username: 94_toy
Post Number: 186
ones High output
Username: Nd4spd18
Northwest PA
Post Number: 7009
High output is a box thats JL sells, not the sub.
And yes they are worth it :-)
Username: Mathxew
Post Number: 14
Why is the continuous power different for the sub and for the high output sub? Does the box help keep it cool?
If i just put it in a ported box can i safely run it at 750?
Username: 420alldaylong
Post Number: 3424
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=475
Username: Nd4spd18
Northwest PA
Post Number: 7010
What are talking about?
http://mobile.jlaudio.com/products_enclosures.php?menu=1&prod_id=189
http://mobile.jlaudio.com/products_subs.php?series_id=5
They both say 750w
