Power Wire
Username: Crayola0
2008 Nissan Versa!!, Wisconsin
Post Number: 2332
What do u guys do to hide it when its inside the cabin like what do u do to hide it or what have u seen done to hide it?
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1682
You remove the foot stepper things(cant remember what their called lmao) and then the carpet will just lift right up and you hide it under there.
Username: Crayola0
Post Number: 2334
ok thanx i think i know what ur talking about. and whats the easiest way to get the wire into the car? cause i was looking at my car and there isnt a spot to go in.
Post Number: 1683
Through the firewall. If you you can't find a grommet then your going to have to drill a small hole through the firewall and seal it with some silicone.
Username: Crayola0
Post Number: 2335
alright thanx and i have some more questions about ur setup but i posted them in the other thread
Username: Redliner
Wilmington, Ma
Post Number: 4136
i went straight up the middle console in my car the footstep that your talking about is an easy way to get the wire nicked. Then water getting on it. Also in some cars the footstep is to small for 9 gauge wire if your going that big
Post Number: 1684
My setup?
Post Number: 1685
do you have a link?
Username: Adddisorder
Palm Beach, Florida
Post Number: 6105
iv got 2 runs of 1/0 hidden easy right along the door and the floor
Post Number: 1688
^^^Yea its pretty easy to hide the wire. I don't see why some people have trouble with it.
Username: Th3pwn3r
Post Number:...
Post Number: 7488
You can also run it under the carpet down the middle of the vehicle like some people do or you can run it under the vehicle.
Username: Bernymac
Cambodia
Post Number: 3798
they're called door sills ;)
Post Number: 1692
Thanks Berny
