Dave
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 170
having micostation and it is saying that my graphics isn't compatible with it
Username: Kingtutus
Post Number: 171
bump
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2296
It probably isn't...
Username: Mesodumm
Tri-City, Az Usa
Post Number: 445
What the H#ll Does micostation have to do with subwoofers???? Let me know!!
Username: Kingtutus
Lincoln, U.s.a
Post Number: 172
he use it to design encolsers
Username: Kingtutus
Post Number: 174
bump
Username: Kingtutus
Post Number: 175
bump
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2298
What are you trying to ask? If your computer isn't compatible with it, it isn't compatible. He won't be able to help you with that.
Username: Kingtutus
Post Number: 176
im seeing if he can tell me if i have the right one or what and to see what type of computer he is running
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5647
well what version microstation do you have?
Post Number: 5648
Username: Kingtutus
Post Number: 177
the newest one
Post Number: 5649
V8?
try downloading directx 9.0
this site might also help
http://selectservices.bentley.com/en-US/Support/Support+Tools/TechNotes+and+FAQs /MicroStation+V8+XM+Edition/9007+-+Requirements+for+MicroStation+XM.htm
Username: Kingtutus
Post Number: 180
thanks it works now
Post Number: 5653
no problem man..was it the directx that helped?
Username: Kingtutus
Post Number: 182
no, i had to get my driver for my graphics card
thanks now time to figure out the program
