Fi Audio Q (12) vs AudioQue HDC3 (12in)
Username: Cozce
I'm debating on which one to get, a Fi Audio Q (12in - $260+$40 for the BP Power) or a AudioQue HDC3 (12in - $229). I'm thinking about getting a Autotek SS1500.1D running at 1ohm, should be around 1500rms. Which one would be loud as hell, yet have fairly good SQ? Compared to each other, which one has the best/most advantages?
Username: Rovin
4 10 Pioneer...
Post Number: 13315
um thats a SQ subs vs a spl sub
AQ should be louder while Q would have better quality....
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1620
"Q would have better quality...."
better sound quality you mean.
Username: Naledge503
Http://www.LowDownForu...
Post Number: 3391
"Which one would be loud as hell, yet have fairly good SQ"
Going off of this statement alone, I would say you would be happier with the HDC3.
Username: 420alldaylong
Post Number: 3343
Fi Q
Username: Chaunb3400
All he does is catch t..., Alabama U.S.
Post Number: 14029
how much space do you have??? I prefer the Q, but the HDC3 may suit what you are looking for better
Username: Stateprop486
PA
Post Number: 1058
the RD alpha gets low n still retains SQ, thats what i heard from chad lee...so mayb look into an RD Alpha.
Username: Spivey17323
Dunellen, New jersey 15 inch Alph...
Post Number: 1470
yes yes
Username: Insearchofbass
Post Number: 8364
the hdc3 12 is loud but the low end has lacking sq...(I personally couldnt live with that...im betting the original audioque hd subs sounded better sq wise on the low end)
Username: Denim
SoundSolutionsAudio.com, MD USA
Post Number: 597
If you build the right box, the Q can get plenty loud.
Username: Cashby
Post Number: 611
x2 ^^
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2229
ive always had aq and dd woofers which lack the sq on the low end and im perfectly happy
ide get the HDC3
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 875
FI Q
Username: Clouduz
Post Number: 321
my vote is hdc3
Username: Cashby
Post Number: 617
Fi Q
Username: Cashby
Post Number: 618
FTW
Username: Jkidder
Gunshine , State Flawda
Post Number: 3347
mach 5 audio spl. but out of the two i'd go with the q if it were me
Username: Deadrabit
Post Number: 234
maybe u should look into the FI BL??? just an idea
its either spl or sql...
