HO alt $$$?
Username: Spankinurwoofers
GR, MI US
Post Number: 348
I got quoted $400 for a 200 amp alt from motor city reman, and $430 from mean green...are these good prices? Any way I could get one cheaper??? In need of one, but don't want to pay out the a$s for it.
Username: Ctmike
Ct.
Post Number: 5897
you could get one cheaper, but it may mean getting one of lesser quality.
Username: Nd4spd18
Northwest PA
Post Number: 6680
If MCR quoted you $400, that's about the best you're going to do for a GOOD quality HO alt. (Think not Iraggi or EA)
GR, MI US
Post Number: 349
is there any way to get the stock one rebuilt for more amps...??? or would that just cost MORE?
Username: Nd4spd18
Northwest PA
Post Number: 6682
No most places that claim to do that are BS
Username: B3n07
Louisville, Ky USA
Post Number: 749
try ohio gen
GR, MI US
Post Number: 350
emailed ohio gen about two days ago, i only got replies from db(couldn't hurt to try, even tho i have a vw), MCR, and MG so far. Didn't even try iraggi, hear too many bad things.
Thanks for the advice tho guys
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7819
depends alos on what brand or model the ho will made...
some alts uses dual rectifiers alternators and they are COSTLY
GR, MI US
Post Number: 351
well, i guess, would it be worth it to buy one? running ~2k wrms...
also, will be a biitch to install, anyone know how to install one on a '98 jetta(mk 3)? It seems like you'd have to take part of the engine apart just to get to it...
Username: Prozack52
Cincinnati, 2-D615D4 Dia...
Post Number: 165
i wil tell you ohio gen will be expensive i got quoted $648 for 220 amperer alt for a s-10
Username: 420alldaylong
Post Number: 3347
http://www.highoutputalternator.com/
Username: Rustywca
I got a HO 300 amp 18 volt externally regulated in a large GM case for 350 bucks for sale, it was on my SPL van so very little use
GR, MI US
Post Number: 354
if there was a way to fit it in a jetta...might be interested, but i'm kinda doubting i can do that. thanks for the offer tho rusty.
GR, MI US
Post Number: 356
is there any big difference between the quality/features/watev of MCR and mean green? like, would it be worth $30 more for the mean green, or is it about the same?
Username: Deadrabit
Post Number: 233
ya man if u can find out how i can fit that alternator in my golf ill buy it from u ! money in hand... to bad it prolly wont
GR, MI US
Post Number: 359
i was told HO didn't make one for my car that's more than 140 Amps...my stock one is 120, so no big difference. (unless you cusom wire/fit it, and that would cost a $hitload)
Username: Nd4spd18
Northwest PA
Post Number: 6697
Ohio will be more expensive. DB or MCR is the cheapest place your going to get a GOOD HO alt.
GR, MI US
Post Number: 360
ok, hanks MS. I'll just save up then, hopefully by early summer I have enough $$$, lol.
ugh, it'd be nice if i actually made anywhere close to minimum wage...
Username: Insearchofbass
Post Number: 8391
M.S...."Ohio will be more expensive. DB or MCR is the cheapest place your going to get a GOOD HO alt."
M.S. from what I remember mcr had the least idle amperage and then db was the next to highest idle amperage ...mcr was 85 to 95 amps I believe and for my car and db's idle amperage was 105 amps on a ho alt for my car with a 200 amp alt so its something to consider if thats the case for his car
GR, MI US
Post Number: 361
MCR's site says that their 200 amp units will put out 90-100 amps at idle...so yea, sean, thats about right^
Username: Nd4spd18
Northwest PA
Post Number: 6700
90-100, 105, negligible difference
GR, MI US
Post Number: 362
there doesn't happen to be somebody on here that sells alts for discounted prices are there, lol? like a rep from somewhere?
cant hurt to check
