15" TC-3000
Username: Skibum12189
Cleveland
Post Number: 2607
15" TC-3000 DVC
Qts 0.407
Qes 0.431
Qms 7.30
Fs 22hz
Res 4.23Ω
Ls 6.1 mH
Lp 13.8mH
Rp 17.38Ω
Dia 325mm
Vas 146l
mms 365g
cms 135um/N
bl 22.6T*m
Spl 87.7dB
Should I go ported or sealed??
I've heard it'll slam either way, but the sealed box should be almost 2.5^3???
Cleveland
Post Number: 2608
more than anything, i want it to sound clean....if necessary, ill go ported, but i want to maximize sq....i guess i just want it to sound real clean and get loud....(run off a DD M1)
Cleveland
Post Number: 2609
BTW
http://www.audiopulse.com/products/subwoofer-drivers/axis/
BTW, the Audiopulse Axis is apparently very similar to the 3k....
Username: Mateo
Post Number: 264
personally, id port it, but pure SQ isnt really for me, i had a set of G5s, and LOVED the SQ, but jsut wanted something more...im putting my 15" Titanium in a T-line....but if you like SQ id say seal her up
Username: Spivey17323
Dunellen, New jersey United states
Post Number: 1137
port that bish :-)
Username: Alex_smith
Post Number: 53
i think with that sub you can maintain nice sq with with a ported box. if you tuned around 32hz you should still be happy with the quality. thats what i would do
Username: Mateo
Post Number: 265
^ fa sho
Username: •cam•
BC Canada
Post Number: 1921
I'd build something other than the regular bass reflex.
Cleveland
Post Number: 2610
any box size suggestions?? including tuning, etc...
Cleveland
Post Number: 2614
bump.
Username: Somedonniedude
Illinois United States
Post Number: 953
I envy you!
bump... i wanna know too
Username: Mateo
Post Number: 276
im building a t-line and horn (in some ways is a 6th order) for my 15" Titanium...if you want i can email them to you
Username: Jakeyplaysbass
Clarion Hert...
Post Number: 2400
Call audiopulse/TC they know way more about there subs than we do... I mean they do make them afterall Cal. :-)
Cleveland
Post Number: 2616
Sh!t should I go ported or sealed??????
I talked to TC and they suggest 3.0 ft^3 with a Tuning Fq of 29 hz Port area of 25 in^2 and Port Length of 18 inches.....
haha, umm i basically know nothing about ported boxes, so wtf does all this mean, i just wanna build a ported box optimized for SQL with sub up and a slot port back
Cleveland
Post Number: 2617
http://web.archive.org/web/20070224172836/http://www.tcsounds.com/tc3000.htm#diy
Cleveland
Post Number: 2619
help me please
Username: Mateo
Post Number: 280
im guessing you dont want the plans for my t-line or horn?
