Wiring to .75OHMS SMART OR NOT ???
Username: Tpa954
Hollywood, Florida U.S.A
Post Number: 207
OK i decided i am going to wire my JL 13W7 to .75 Ohms i am going to be using a US amp Merlin D3 2000WRMS which is one OHM stable. I was wondering is this to much power for 1 of these subs and is his going to kill my amp . I have big 3 done, Orbital 78DT battery .
Username: Denali_on_22s
The kids like my rhyme...
Post Number: 4167
could have been answered without starting a new thread, but yeah you should be alright. with imp. rise you could see 1 ohm...
Username: Nd4spd18
Northwest PA
Post Number: 6214
You are most likely going to need an HO alternator to run that amp.
You DEFINITELY need one of you're going to run .75 ohm.
Lower impedance = more current draw = blown amps, if you do it with an inadequate electrical system.
Username: Nd4spd18
Northwest PA
Post Number: 6216
Just read in your other thread you have a HO alt...... you should be ok then
Username: Nissankicker
Grambling, LA USA
Post Number: 244
I'm running my Diesel Audio NSH-1.3000D @ .5ohm... ( 3116 rms )
... Stock Alt, (2) Yellow Top Optimas, Big 3. ( Batcap 800 coming soon )....
And it's fine...
Quote: I'm in a '99 Nissan Sentra GXE
Username: The_mod
BANVILLEUSA
Post Number: 11
Ok with a true 2000wrms from a class D amp, you are looking at around 200-220A of current draw.
The amp should be ok at .75ohm, but you had better have the electrical to back it up. You can install it w/ your current electrical system, but check the voltage at the amp while playing. If you are getting substantial drops in voltage (which you most likely will) beef up that charging system.
Post Number: 4179
you said you had a 200 amp alt in the other thread
Username: Tpa954
Post Number: 212
No. I was going to purchase a 200 but ened up getting a 170 due to money at the time . Y
Username: Nd4spd18
Northwest PA
Post Number: 6227
30 amps could make a big difference you should have got the 200
Username: Tpa954
Post Number: 213
It was like 150 dollar difference didnt have it at the time just moved ..... :-(
Username: Insearchofbass
Post Number: 8002
I wouldnt do it if i was you...not worth risking an amp in my opinion
