MA audio
Username: Moey_g
SydneyAustralia
Post Number: 179
Just curious about MA audio amplifiers. Specifically the one in the following link:
http://cgi.ebay.com.au/MA-Audio-HK1998-2400W-Mono-Block-High-Performance-Amp_W0Q QitemZ220200181323QQihZ012QQcategoryZ18797QQtcZphotoQQcmdZViewItem
Ive never had any experience with them or heard anything about them. I checked the Good/bad list and MA Audio is under 'bad' in the general section but under 'good' in the amplifier section so i thought id ask here.
Is it any good or should i go with a Soundstream amp over MA audio?
Please no recommendations on other amps as most of the amps in the US are not available in Australia.
Thanks
Username: Imback2500
Post Number: 13
i dont know u so u can slide
im on a rampage today
Username: Snowball123
West Allis, WI United States
Post Number: 294
i dont think ma audio is very good.
Post Number: 18
let me guess snow he should get fi
fi sucks
Username: Moey_g
SydneyAustralia
Post Number: 181
Would you recommend soundstream over MA?
Post Number: 302
whats your budget? and for like how much power.
Post Number: 307
you cold get an audioque 1200D. its got the same ratings as that. way cheaper. and way better. its on www.audioque.com
Username: Moey_g
SydneyAustralia
Post Number: 182
Like i said, most companies in the US are not available in Australia, if overseas shipping is available it will cost as much as the amp...
If you had the choice between a soundstream amp and an MA audio amp with similar ratings, which would you choose?
Username: Nd4spd18
Northwest PA
Post Number: 6217
MA audio = sucks
SS = not very good either but better than MA
