Ot-most powerful RMS amp?
Username: Ska
Post Number: 444
i was just curious about this... i look it up on google and only find the most powerful system:-(
Username: Snowball123
West Allis, WI United States
Post Number: 316
rockford 15K? maybe
Username: Dakangofkrunk16
Post Number: 1085
http://www.lightav.com/car/amps/poweramps.html
Username: Ska
Post Number: 445
what was that one amp that was banned from some comps?
Username: The_mod
BANVILLEUSA
Post Number: 8
Harrison Labs DragQueen
Username: Imback2500
Post Number: 66
sony explod 200w
is the loudest so far
i have it hooked to my tc sub
stupid phuckers
Username: Th3pwn3r
Post Number:...
Post Number: 6857
The Harrison Labs DragQueen is banned from DB Drag :-(
The Kicker Warhorse has been said to put out 20K RMS but who knows. They also claim that the Warhorse is extremely efficient needing only something like 5-600 amps to produce that power. I forget who it was but they switched from 8 ZX2500s to a Warhorse and put up a better number with all the same equipment sans the amplifiers.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2218
"switched from 8 ZX2500s to a Warhorse and put up a better number with all the same equipment sans the amplifiers"
WOW
Username: Nd4spd18
Northwest PA
Post Number: 6224
" The Kicker Warhorse has been said to put out 20K RMS but who knows. They also claim that the Warhorse is extremely efficient needing only something like 5-600 amps to produce that power "
Come on Rob, I though would know better than this.........
If that amp was 100% efficient (which it can't be) it would take 1388 amps at 14.4 volts to produce 20kw of power.
If you got those numbers from Kicker, somebody there must have failed elementary math :-)
Username: Th3pwn3r
Post Number:...
Post Number: 6864
Well the amp is rated at 2ohms for 10K Rms. As I said "they" claim and this was a competitor putting out some numbers that was using it. Who said anything about a 14.4volt system M.S.? I'm not sure what kind of voltage they used to feed that amp but regardless of what kind of current draw the amp is said to be top dog by the select few that have had the privelage to use it. Kicker recommends 2 200amp alternators and 8 batteries to feed the amplifier.
Username: Jakeyplaysbass
Clarion Hert...
Post Number: 2402
(2) Stetsom digi 7kws strapped. :-)
Clarion Hert...
Post Number: 2403
...I think you can strap the 7kws at least.
Username: Ska
Post Number: 451
why was the dragqueen banned? i don't get what it did? lol
Username: Jkidder
Gunshine , State Flawda
Post Number: 3231
it stored the current and let it all out in one rip. wasnt a daily amp atttt allllllll. i read somewhere that it could run of a 60 amp alternator too....
Username: Jkidder
Post Number: 3232
oh yea, 20k at .25 ohm for upto 30 seconds.......
Username: Insearchofbass
Post Number: 8001
sweet got any pictures of it
Username: Nd4spd18
Northwest PA
Post Number: 6228
Well I assumed they would be taking about 14.4 volts unless they said otherwise
Username: Ska
Post Number: 454
how much power did it put out in the burp?
