Box size and Tuning frequency
Username: Ducka
Shelby Township, MI United States
Post Number: 34
What would be a good box size and tuning frequency for a 4" ported box that will be holding a single 12" Alpine Type-R? I am going more for SPL than SQ.
Thanks,
Kevin
Username: Mendonmafia
Post Number: 1174
2 cubes tuned to 32-36 hz depending on vehicle size.
Username: Ducka
Post Number: 35
Its an olds alero. (basically a grand am) what frequency would you suggest? Also what would be the difference between 32hz and 36hz?
Username: Insearchofbass
Post Number: 7974
do not use a standard four inch port ...its not enough youll have tons of port noise... even with a 4 inch aero youll probably have decent port noise
Username: Ducka
Post Number: 36
what would you suggest? a 6 inch?
Post Number: 1176
slot port. in your car id tune to 34ish hz there not that big.
Post Number: 7985
yes make a slot port... 28 square inches
Username: Ducka
Post Number: 37
okay so to tune to 34hz in a 2 cube box what would be the dimensions of the slot port(length, width, and depth)?... If you know of any calculators that can figure this out I can do the work myself.
Post Number: 7992
http://www.carstereo.com/help/Articles.cfm?id=31
select square and yes to slot port
Username: Ducka
Post Number: 38
Using the calculator I am getting a port length that maybe too long for my box. Ill put up pictures.
Username: Surferdude9371
Im BTL Bumpin
Post Number: 645
ya i think that calc is Fed up i have the same prob
Username: Rovin
4 10 Pioneer...
Post Number: 13110
thats y u make it into a "L" port
try this then http://www.subwoofertools.com/forum/ported-box.asp?Ew=30&Eh=15&Dia=6&Xmax=18.2&V d=.071&NumW=1&Vb=2&Fb=32&Qts=&Vas=&Fs=&CE=0
its alot simpler to use .......
Username: Ducka
Post Number: 39
I had to make the port go out of the box so that it would be long enough. If there is nothig I can do about it will this set up still work?
Username: 2000celica
Roanoke, VA U.s.
Post Number: 97
making the port a little deeper in length will give you more port area. maybe keeping it all inside of the box.
Username: Ducka
Post Number: 40
wow that other program is much better thank you very much, but is a port that is 2.25 inches wide wide enough?
