Voice coils and motors
Username: Somedonniedude
Illinois United States
Post Number: 944
Do most company's build their motors to accommodate certain VC configurations, or is FI the only ones who do that? If someone can give me a heads up of what company's do or don't do this it would be greatly appreciated.
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2141
you mean like you can choose what kind of coil you want with your sub?
Post Number: 945
Not exactly. FI has their "universal" option so that if you ever decide to recone the sub you can switch to a different vc configuration, since each motor is designed to work to its best with that certain coil. So I was wondering if other companys made their motors the same way as FI did, where you can only use that same coil config as it was originally built with.
Username: Snarl2004
Post Number: 2143
oh i didnt know that. so if you buy a motor that was origanaly designed to be dvc4ohm and you recone it to dvc2ohm it wont sound as good or work correctly?
Post Number: 946
I am assuming so with FI if there is no universal option.
Post Number: 949
Bump
Can anyone refer me where to look? I'm more specifically looking into Tc9 and 3hp motors.
Username: Mateo
Post Number: 266
not tyring to be a d!ck at all but your going to have a hard time finding a top assembly for those motors...but ya might get lucky...as far as the FI....i dotn believe thet voice coil size changes or antything just the impedence....but once again i could be wrong since ive never dealt with them...but good luck with everyting....ill let ya know if i come across antyhing you could use
Username: Philly306
I get higher golf scor..., North carolina
Post Number: 872
http://www.tcsounds.com/support.php
the ones with asterisks have interchangable top assemblies. don't know if that helps
