JBL GTO And Kicker L7
Username: Kickz_l7
just bought a 12" Kicker L7 2ohm dvc sub box is already built its sealed in the back of a 95 Ram 1500. I need a little bit of help on an amp that i want to buy it is a JBL GTO 1201.1 787RMS W at 4ohms. I think the altenator in the truck is a 120amp altenator (not sure) will the trucks altenator be amp to handle that amp? more info The amp has 3 40amp fuses so 120 amps is the most the amp will pull i was told will i need a high output altenator?
will be doing the big 3 with 0g and a deep cycle battery.
AMP SPEC'S
JBL GTO1201.1
12dB per octave electronic crossover
~ RCA low-level inputs
~ Full-range preamp outputs
~ Variable bass boost circuit for optimized system response
~ 787 watts RMS x 1 @ 4 ohms
~ 1114 watts RMS x 1 @ 2 ohms 14.4V supply
~ Dynamic Power 1339 watts at 2 ohms
~ Damping Factor: 6.348 at 4 ohms
~ Frequency Response: 10Hz - 302Hz
~ Maximum Input Signal: 6.1V
~ Variable electronic crossover and bass-boost
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5142
yes it will handle it
Username: •cam•
BC Canada
Post Number: 1810
Looks good. You should be fine with that amp. It will draw less current at 4 ohms.
Username: Killswitchjd
Post Number: 717
ya, and not to mention your ears would not like it played at full volume, this would hurt.
Username: Juliob
Post Number: 5149
until you get used to it
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1350
You mean until your ears bleed..^^
